Help with Apple TV+ app on Sony TV
Just started a 3 month trial.
Have added several shows to the watchlist.
But for the life of me I can’t find the frelling watchlist under any of the menu options. So I can view them.
Where the heck is it?
All the Best, Jeff
They should be in the “Continue Watching” row.
Thanks.
I tried to do that and I must be doing something wrong.
Your answer is in line with others I’ve found on the web.
All I see is the show I’m currently watching.
Really annoying.
Seems like apple is stuffing suggestions everywhere I look.
All the Best, Jeff
I would have expected that if you keep scrolling upwards on the main screen of the app that you will eventually see them. I had AppleTV+ earlier this year–sorry I can’t quite remember.
If you think it might be a bug, you could try forcing a true shutdown of the TV. (I think it is typically in standby by default). With my last Sony you just had to hold down the power button on the remote and you’d know you got a true reboot when you see google logos popping up on start.
Don’t think this is Sony issue.
It’s the Apple app problem.
Lots of folks bitching about in the Apple support and elsewhere.
Many complain that Apple tech was no help.
Thanks again.
All the Best, Jeff
Right, but I figure maybe the app is glitching and not loading what it should.
My thinking was the easiest way to refresh the app might be to restart the machine. If you want to do more work you could probably dig into the apps management area of the android settings and clear the cache for the app. This would likely mean you would have to log back into the service but that would also probably work
