I’ve got a new Emisar D1 that is great. I’ve also got a D4V2. I flashed the latest Aduril on the D4V2 with no issues. My OCD told me I should flash the D1 as well. It has the same six pads on the exposed side of the driver board so I used the D4V2 flashing kit and set the MCU type to ATtiny85 in ZFlasher AVR. It tested successfully so I flashed it. It completed with errors and now it won’t turn on. I know I’m an idiot and should have left it well enough alone but I didn’t. Any ideas how to go about getting it working again?
Well, hopefully it’s not bricked, you just need to flash correct firmware. Have you tried compiling the D1 config and flashing it?
The D4V2 uses a attiny1634 which has more pins than an attiny85, so you can’t just change the MCU type and compile the same code. Hopefully you’ve just erased the chip and it needs firmware loaded again.
Worse case, I’d be glad to take it off your hands
I’ve always wanted a D1
Hank straightened me out.
Apparently the D1 that is shipping now uses the ATTiny 1634 MCU and the D4V2 firmware.
Good to know! Thanks for the update. I assume you’re back in action now?
Yes, the light is back in action and I’ll be a little more careful before I start flashing any more lights. ![]()
You need the D1v2 firmware here: http://toykeeper.net/torches/fsm/anduril.2020-03-22.emisar-d1v2.hex
Thank you, I missed that one since it wasn’t a 3-18 build date like the others.
