Does anyone know if it’s possible, and which component I should modify so that the 3X21D driver only delivers 12A on turbo?
I believe I would need to replace some resistor, I’m just not sure which one.
It might be possible by increasing the resistance of the sense resistor. On the right in your image next to the red wire is a resistor that reads R002 (2 milliohms), try replacing this with a 4 milliohm one.
Ive never tried it with an e-switch driver but i imagine itll work the same. It should cut the output of all the modes by half
I suspected it was that resistor because of its size and its position next to the inductor. I’ll run the test and give feedback. thanks!
