Help with flooder recommendation with 2 or 3 18650s
My fandy fire Warrior is out of commission and I need another good flood light for use in basements and attics. I have plenty of good 18650s so no 26650s. 2 or 3 18650s are good. I think 4 would be wider than I like. I’m thinking multiple xml’s or a single mtg. The cheaper the better but for a limit let’s say under 50$. Any ideas? Remember flood, not throw.
I know throwers are more exciting, but I thought I’d get at least one response. :slight_smile: I must have posted at a bad time. I just ordered a New-117 to put an MT-G in to get me by for awhile. That should be a good size for me with adequate run time. Looks like it’s big enough to take most stars. If anybody has some ideas, I’m still looking for another replacement for the Fandyfire YL-02 Warrior of mine that bit the dust. Or a replacement driver for it, tho my modding ability is limited. Thanks.
I have the Solarstorm version of the Warrior, and I like it. Why not stick to something similar - the Solarstorm T3 is $30 and the T4 $34 at Fasttech. They changed the UI somewhat, but for the price they may well fit the bill. Just a thought.
Convoy S2 maybe? It’s only 1x 18650 though…
I forgot about the solar storm. I’ll have to check that out again. I have some single 18650 lights but they just don’t have the needed lumens and are too much spot. I’ve been filling in with an hd2100 real similar to the S2 and I need more lumens. Tried my ZY-T08 also and just not enough flood. I take a lot of pictures in dark spaces and flood works much better to illuminate problems areas. I’m a home inspector.
the JM30 is hard to beat. you can buy an extra and run three (yes it will take 26650 but by definition it will also run on 18650)
check out MAD MAX’s thread for codes
