help with machine cabinet lighting upgrade
As title please.
I have 2 strip/light bars at present but they could be better. The power supply in the back of my wet blasting cabinet is 24v. Please see link below for pic
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=2ahUKEwj4jbTt7O_dAhVNyRoKHY-ZBi0QFjABegQIBxAC&url=https%3A%2F%2Feshop.wieland-electric.com%2FshopWieland%2FgetProductDownload%2FIM0098825.PDF%2F81.000.6530.0%2FTechnical%2520data%2520sheet%2520-%2520Catalogue%2520extract%2F.PDF&usg=AOvVaw277AAJwPVZyVwyDPKfjRGP
I’m guessing I could just find a 24v 30-40w off road light bar with a flood pattern or something like that? Any help I would be very much grateful for.
Cheers
Dave.
I have a dry blast cabinet and also need to add more light.
I have 2 110V floods but they are mounted on the back of the cabinet, which makes some items very hard to see.
I was thinking of adding a 5M strip of LED’s to the front side.
I would use Automotive Trim Tape to hold them in place.
I have everything on hand so it’s just a matter of having some time to install them.
I think the Off Road lights would do a nice job.
How big is your Cabinet ?
The pictures don’t show your cabinet, but if you think off-road lights would work for you, then they probably will. Electrically, you have up to 120W of power available at that power supply. The best light bars you will find, and reasonably priced as a bonus, are going to be the Mountain Light Bars by Richard from Mountain Electronics, who is also member RMM here and a great guy.
EDIT: If you think you could, an alternative is to modify those light bars you already have or buy new ones that are higher wattage. The label in the pic says 9W, so both of them together are only 15% of the rating of the power supply. If there’s room, you could even just add some more of those, if higher powered ones aren’t available.
When I looked on Ebay a lot of the light bars are 2000W.
A little bit to much for his power supply.
Well, there are plenty of cheap, low-power light bars in the world. Check out Tractor Supply for the U.S.A. I’m sure there are similar places in the UK that Davevo 5K can find them if super cheap is the desire. Also, eBay does have lower powered light bars, so I’m not sure what you’re even getting at.
This pic is useless without threads…
I’ll sort some pics out later today.
Last night I just took off the diffusers and it made it quite a bit brighter! Facebook
Wet blaster is on the right it’s 1.2 mtr wide and the light strips sit behind the front cover. The dry blast cabinet has a 50w led floodlight that shines through a glass panel on the top.
