I have a QLITE REV.A 7135*8 driver, rated at 3 Amps and I am using it to drive a Cree XP-G2 with a single Panasonic NCR18650B Protected cell. The problem is I am not getting 3 Amps out of the driver. Here are the measurements I got:
Battery Voltage: 3.78 V
Tail Cap current: 1.61 Amps
LED Voltage: 3.33 V
LED/Driver current: 1.51 Amps
So I am only getting half of the rated output current. The Qlite driver is original in default mode and has all 8 chips. Any idea what might be wrong or I am missing something?
I am using a multimeter to measure current and voltage. For reference I have a Nanjg 101-K-A1 driver rated at 1.4 Amps and with the same setup I get 1.35Amps at the LED with that driver and about 1.05 Amps with a Nanjg AK-47 driver rated at 1.05Amps.
Many have reported the same with the later XP-G2 leds…the Vf is too high hence the lower tailcap readings. I have the same problem with my XP-G2 S2 with a DD driver.
FYI, many have reported the same with the XM-L2 U3s.
yes, there are issues with Vf on the new led’s, but normally that doesn’t come into play until you are up in the 4-6 amp range.
Try charging your battery up to see if that makes a difference, but I think it’s most likely your DMM leads. The stock leads on my DMM wouldn’t read anything over 1.7amps (and its a quality DMM) so i upgraded the leads to 12 awg
You’ll only see 3A if you charge your battery. The high Vf is the issue, as stated by tristanxoxo. Once it drops below 3.6-3.7v under load it’s going to drop out of regulation.
It should be able to deliver 3Amps with battery voltage as low as 3.6V. The current the driver outputs drops to 1.5Amps only when the battery voltage is around 3.2V. So according to this review a voltage of 3.78 is not low enough to cause a drop in current, right?
I feel a bit old posting this, but XM-L is one thing XP-G2 is another thing, for the same current, the vf of the XP-G2 will be higher than XM-L, like for example at 3A.
But first use short and thick leads on the DMM, after all you want to see high current at low voltage, ohm's law will tell you that you need low resistance for the entire circuit that the DMM creates. Also charge your cell, the 8*7135 will drop around 0.12V by themselves.
I took a measurement with a fully charged battery and the numbers are a little better but not quite there yet:
Battery Voltage No Load: 4.24V
Tail Current: 2470 mA
Voltage across LED: 3.56V
Current through LED: 2090 mA
The measurements where taken half a minute or more after the LED was turned on. I am still not getting the 3Amps that the driver is rated for. According to this plot from the driver review
at 4.24V current in and out are both around 3A. In my case it seems I am drawing more current than I am using for the LED. Based on your comments the only other thing I could try is using thicker and shorter DMM leads. I will see if I can find any. What gauge leads are thick enough, 18AWG, 16AWG?
You may be surprised what difference you see when you switch to using the heavier gauge wire (and SHORTER length) for the DMM leads. I know that I have been (over and over).
