I recently did my second build; an L2. xpl hi emitter and driver from mountain electronics. I am not very good at soldering and the light comes on in high only. The nice man from Mountain stated I have a short between the led and ground. What does this mean and how can I fix it please.
This happened to me once on my L6. See if the reflector base is touching your ground solder wire on the star. I had to make my negative solder blob lower and also added kaplan tape to protect both + and - from the reflector base.
That did not work. I took the reflector off and it still remains in only one mode. I inspected for obvious issues and could not see any problems. Is it possible for the driver to be damaged?
