Hi from newbie
I’m new here - I’ve been browsing around a few weeks and decided to join.
It started with some Christmas present a few years back from a friend - an Ultrafire 601A powered by 2 AAs.
I think it has an xr-e p4 emitter. This was my hunting and fishing light for many years and worked well.
Then he gave my kids a Sipik this past year and that got me to investigating!
I got a few 18650 protected batteries, a mp1s charger, a laptop packs worth of unprotected ones after realizing
that AA’s will only go so far. Also got a Convoy M2 2100 mah u2 emitter, its a great light! I was tempted to
get the 2800 mah one but wanted a ‘usable’ high mode with more runtime and less heat. This will be my new
general purpose light. I like also that its fatter but shorter than the 2 AA lights.
Now I want to get a C8 - thinking about one on ebay because it’s US shipper (fast) and cheap:
c8 on ebay
Are these good lights? I just don’t want a surprise like: not an xm-l emitter or it doesn’t work.
Thanks for input
Hi clifford. I’m fairly new here to, but have been working with LED flashlights for several years.
The flashlight you linked to looks good. I don’t know anything about that seller. I don’t like that it doesn’t specify the power that the driver outputs to the LED on high. If weak, you will end up spending about $5.00 for a better driver. The pictures also seem to show a lot of small nicks on the finish. My experience with ebay is hit and miss. Hopefully, it has a good pill, instead of one of those completely hollow pills. Just can’t tell because they don’t show the internal parts.
For $2.75 more, you can get a sure thing with a higher bin emitter (xml u2) and a driver that puts out 3 amps. I have one of these and it is a nice light. Really cranks out the light.
http://www.lightmalls.com/ultrafire-c8-cree-xm-l-u2-1300-lumen-5-modes-led-flashlight-1x18650
For $3.39 more, you can get a C12. It only has the t6 bin xml. Mine has the 3amp driver, but the link below does not specify that. You should ask them before purchasing. If you think you may want to modify the light for higher current, this light is better because it has better heat sinking. I really like this light.
http://www.lightmalls.com/ultrafire-c12-cree-xm-l-t6-1200-lumen-5-mode-led-flashlight-2x18650
Welcome to BLF. This is a great forum.
Sup!
Don't expect a C8 from an unknown dealer to be well-driven. Especially if they claim an unrealistic 1300lm from an XM-L.
If you really want something that outputs as well as that Convoy, you'd probably have to replace that driver yourself.
This is driven around the same level as your M2: link.
This is a Convoy C8 that is driven at 2.8A: link.
On any light you buy, check the heat sink connect between the pill and the LED base (star). Most light are assembled by folks that don’t really understand or care about that detail. I almost always have to redo that part.
I just saw Ramblings suggestions. Fasttech is as a great outfit. I buy from them all the time. I like how they multi-mode selections (3-Low,Med,High and 5-Low,Med,High,Strobe,SOS). Most people find the flashing modes obnoxious. Those lights look like that have really nice ano finishes too.
We're glad that you joined, clifford!
Glad to have you on board, clifford. The more the merrier. :party:
Hello Clifford and welcome to BLF ! ! ! :party:
Hi and welcome Clifford. You could use the search function and get lost for a couple of days. Good luck.
