I have already 2 Kings modded - one with those triple-aluminum boards with High-CRI Nichias from FT, one with triple Noctigons and XP-G2 S2s - both with the different versions of the RMM driver (Aluminum board = 7135 driver, copper = FET)
Now I would love to have a combination - 5000K High CRI.
Since I am a bit out of the subject - is there a LED\* that is perfect for me and available on DTP Copper?
This time I would use my Ultrafire UF-T90 - even though I have two other Kings laying around.
Thank you very much!!
*Is “a LED” correct? “an LED” sounds far more correct to me, but the rules say, that “a LED” is right…
I’m not sure what you see.
At least the description on Kaidomain says it is DTP, and Kaidomain did start selling a black line of DTP boards recently.
They have become pretty good in leds the last year, with a good collection not seen elsewhere and showing pictures of the packaging too so that you really know well what led it is.
The paint is just solder mask, which is a final layer on top of the board to insulate parts where you do not want solder, apparently Kaidomain decided to cover that bit.
the title of the product on the website:
“Triple Nichia CRI92 NVSW219BT-V1 5700K LED Emitter with 20mm x 1mm DTP Copper PCB (Parallel) w/ optics”
btw, the price is unbeatable: $7.87 and even an optic is included! edit: the BLF coupon makes it even $7.48.
If you pronounce LED as “LED” then “a LED” would be correct.
But we pronounce LED as “el e dee” and because the first syllable starts with a vowel, “an LED” would be correct.
That’s why it sounds better to you. It is correct.
Bravo, if you are German and English is not your first language. You are very good at it!
