high current drivers and wires question
hello ,2 question about drivers/wires
2 nanjg 105c 5,7Amps and 4,5Amps will be ok with 22awg wires ?
also 26awg wires are ok for 3,4Amps ?
Depends on what you consider as “OK”
22awg for 1A, 18awg for 3A and 16awg for 5A are OK for me.
Depends also on the length when trying to figure out what gauge to use for your devices.
lenth is max 2cm
At 4cm (2cm each) at 4.5A the voltage drop is 0.00972V (0.01v) and 0.01231v at 5.7A for 22AWG. Would not use 26AWG at all.
So yes, 22AWG with each lead 2cm long is good.
Hm. I’ve been using 22 aug for everything.
I have some 16 aug silicone wire but it’s HUGE. I have no idea how’d ever get two wires of it through the center hole on a 20mm triple Noctigon.
nice thanks you for the tips.
Don’t you have a drill? :bigsmile:
I have a real easy way of calculating the correct wire size, I just use the lowest AWG I have that fits.
The American Wire gauge Table is where I look to see what to use. Divide the ohms per thousand feet by 10000 to get ohms per 1/10 foot(move the decimal 4 places left) and multiply by the drive current to get the voltage drop. .1V in the wiring is not good enough IMHO so I would use whatever gets me to .01V or better. Awg 20 will do that to 10A and is in fact rated for 11A chassis wiring. Awg will do for up to 4A and awg 30 for 1A.
22Ga lets over 15A run in my L2m shorty. The wires are about an inch long.
The less voltage drop in the wires the higher the current you will see through the led with an FET driver or longer time in regulation with a 7135 driver.
I’ve found that 20 ga wires or more tend to rip the solder pads off drivers. So I seldom use 20, never anything bigger.
i haev the same problem with 18-20 very easy you can destroy the board ,you must solder them in a position where the wires will not need to move a lot.
