I was just wondering if there has been, or better yet there is currently available high quality zoomie powered by a single 18650 battery. I have seen countless post asking about the quality of a certain light, and the replies have always been the same. They are cheap, never really know about the quality, poor machining etc. It seems with all the talent of the members here, and the continual interest in a high quality, high power zoomie that someone would have made one. We know have lights that are just bigger than a 18650 battery that are pulling 6 amps, and powering triple leds. Maybe I am greedy, but having a light that works just as well up close as it does far away would be great. Or is there any modder out there that would be interested in under taking this project?
What i wonder is why big brands as Fenix, Trunite, Nitecore and so on, dont offer zoomable flashlight? you can make ~ 50 mm head based flashlight, for all possible purpuose one can imagine….you need throw? you got it, you need massive flood? you got it…you need good size, and portability? you got it!
On the other hand, i think the problem is that in that way, they cant milk 100 + models, since all will be satisfied with a single one.
I would like to have a high-quality zoomie too.
Zoomable flashlights with aspheric lenses tend to produce relatively ugly beam patterns compared to conventional reflectors. Most of them have rings. The flood mode isn’t as wide as a reflector light, and the spot mode works… but produces an ugly image of the emitter.
The cheap zoomable market is dominated by the budget makers, though there are a couple expensive premium brands (Lenslight and Wolf Eyes).
There is a superior type of optic available that combines a TIR surrounding a small aspheric lens. Unlike a traditional aspheric, the optic has a pocket in the bottom. The LED is mounted on a pillar and moves up and down in this pocket…. but because the optic surrounds the LED in both flood and spot mode there’s no loss of lumens in spot mode like with a typical zoom light. This type of optic requires specialized engineering though, so is more expensive. Also the patent on it is held by LED Lenser.
Best way to get a high-powered single-18650 aspheric is to mod one yourself. I’m in the process of doing that right now. Just finished installing the sideswitch on my Aleto N8. This was the smallest 18650 zoomie I could find at 108mm x 24mm stock. At the present point in my mod I’ve shortened it to 102mm.
Tomorrow night I’ll probably remove the tailcap switch as it’s no longer needed since the sideswitch seems to work well. With the tailcap switch removed I figure I can shorten it to around 95mm. When the mod is complete, the finished light should be similar in size to a Sipik 68… narrower than the head of a Sipik 68, but a bit longer, and heavier due to the larger battery. Powered by a Samsung 20r 18650 and Nanjg 105c with Comfychair FET mod and DrJones lumodrv firmware it should pull around 6 amps with a dedomed XML2.
I also modded the flood mode so it’s nearly 90 degrees wide - that’s over twice as wide as a Sipik 68, and wider than most of my reflector lights. Blows any stock 18650 zoomie away in output in both flood and throw.
Wolf Eyes makes high end zoomies, The Uniquefire UF-T20 (e.g. ~$20 at Wallbuys) is a budget-clone of one of the Wolf Eyes lights, that is still a very decent quality. The beam brightness of the UF-T20 can be improved by using a different led and a copper board (many posts about that).
I have several of the optics you are speaking of, I’ll see if I can build one into a light and get it to work. Thing is, they were designed specifically for the xre, I don’t know of another emitter that has a primary optic built into the dome itself.
Being that I’m a neutral on copper guy, it may take a bit, but I have something I think may work assuming I can find the parts.
No promises to the op, but if I do come up with anything I’ll let you know.
I don’t have any problem with the quality of most of the budget zoomies I have bought. I do have one shoddy one that was sent to me without my ordering it. I especially like my Yezl T9, my Sipik SK-73, all my SK-58s and my Raysoon 398 SK-98 clone (with driver replaced to cure next mode memory). Also my Smiling Shark SS 8027, which is the only moving pill zoomy with good cooling that I have ever seen, and my TrustFire Z8. I don’t understand why people complain that they can’t pay more money for zoomies. I don’t know why there aren’t more expensive zoomies, but why complain?
not really a zoomie, but it can sorta act like one ….fenix tk76
