Higher voltage XML single mode modules/drivers from KD, which one is pushed hard?
I found two XML modules on KD that MIGHT have enough amperage to the LED to push to promised numbers... So far I found only drivers pushed at 1.5A which is not enough for my project (MiniMag Triple XPE run with two IMR14500, like Match did with his legendary Mini-Match)...
Anyone knows if any of these is close to 3A ???
http://www.kaidomain.com/product/details.S020142
http://www.kaidomain.com/product/details.S009985
Thanks in advance...
The second one 9985 is driven at 2.2 amps with a single 18650 not sure about other voltage readings. I don't own the other one.
That's promising amp draw... should be rather good for MiniMag mod...
Thanks for input, E1320...
How will you fit 3 XPEs in a minimag? Triple-emitter-star?
Triple LED from LEDSupply with narrow optics... with lathe, it is VERY simple upgrade... with outstanding results...
Match is the man...
