Hobby Charger and LiIon charging cradles
I bought an Accucell 6 as I get most of mt 18650'sfrom laptop packs, and needed a way to check them carefully.
At a charge rate of 1 amp per 18650, with the cutoff automatically at 1/10 of that or .1 amps, usually results in a resting voltage of 4.18 volts with a good cradle,
My first charging cradle was simply a pair of magnets attached to the standard clips.
Then I cut up a coat hanger and used two short straight pieces of coat hanger with magnets to charge 2 batteries at once in parallel.
That worked well but was awkward and clumsy to set up.
Balance charging seemed like a good idea so I made a 2S1P charging harness using magnets and tried that for a while, comparing results with the parallel setup.
I found that parallel charging was either slightly or much faster than balance charging so since then I've stuck with parallel charging as it was both faster and more consistent.
I gutted a junky charger and made a 1S2P cradle out of an old Trustfire charger
That wasn't bad, but the high resistance of the slider connectons (through the spring) meant that resting voltages after charging were about 4.15 volts.
I picked up a 4 way cradle from Fasttech (SKU 1279305) that came with separate wires for each positive and negative end and made a 1S4P cradle out of it.
That worked well - except that removing batteries was difficult as the heatshrink kept getting caught under the ends of the clips in each bay and there was the possibility of shorting out the positive end if I wasn't very careful.
So I bought a 4 battery USB portablepower pack - without electronics, from Fasttech (SKU 1280801)and attached the wires from the other pack to it.
Picture of modded USB pack.
Thats my current setup for 1 - 4 unprotected batteries and the modded Trustfire is used for protected batteries.
I would go back to the slider and attach my wires directly to the contact part of the slider.
nice work!
I hope you don’t mind me resurrecting an old thread. Anyway, here’s my parallel setup. Unfortunately, it only handles unprotected 18650’s. Not a problem for me since 90% of my cells are unprotected. For my protected cells, I use magnets, or I’ll use one of my Xtar VP2 chargers
I bought one of those cradles too. Almost impossible to extract the cells once they are in. It was designed for putting the cells in and leaving them there. To make it easier to extract the cells I cut away the sidewalls between the cells in an arc, but when I did that the walls being so thin and cheap caused the whole cradle to warp and loose contact.
So I threw it away.
Everything is junk and I am sick and tired of it.
I go in the opposite direction, instead of a better quality low cost item (battery holder), I bought a junk charger that doesn’t work at the swap meet cheap and gut it out.
On the sliders use a good fine stranded wire and connect directly to the sliding part that makes contact with the battery.
I wouldn’t do a parallel charger. The hobby chargers support multicell serial charging with balancing, which looks better to me.
I drill holes in the bottom of the holders under the positive end of the battery and push them out with something soft.
I use a plastic spudger tool on the positive end to remove my cells. It’s easy, and causes no damage to the cells, or the cradle
I’ve been doing parallel charging for 5 years now. I always check the voltage after charging is done with my Fluke 289. My cells are close enough for rock N roll. Basically they self-balance
Nothing to worry about parallel charging, in the RC hobby world high capacity LiPo packs often comes in 2P/3P & 4/5/6S setup, the balancing is done only across the cells in series not in parallel, and those LiPo packs are used for extreme high current application where a unbalance is most likely to happen.
For Li-ion as long as they have similar IR, capacity and close production date you can parallel charge all the time without worrying.
Agreed
I’m not concerned with parallel charging, but putting 4 cells that aren’t balanced already into a parallel holder must have some moderate to serious insta balancing going on.
Read this old thread Li-Ion Parallel Charging | Candle Power Flashlight Forum
They measured the current that flows when cells of very different voltages are connected, up to 2 volt difference.
.5 volt difference is a conservative, safe recommendation and would seldom be exceeded with cells requiring recharging.
Good article, but for their test it was just two batteries, one low and one fully charged. A cradle of four could have one fully charged and 3 discharged with 3x the current flow, which with their numbers would be almost 20 amp initial surge and 7.2 amps once it settled a bit.
I think the key here is to know your batteries. I keep mine in matched sets, so I know they are within 10 to 20 millivolts of eachother before I parallel charge. So far it’s worked for me. And yes I do contantly monitor my batteries to make sure they stay within that parameter.
