Well all this talk about copper sink pads and I don’t have one. So I thought well, there’s more than one way to skin a cat.
So I took a aluminum 14mm pcb and machined out the rectangle center of the led pad. Then took off about .050’ of the back side of the pcb to thin it. Then made a flat round off of some copper stock I had. Stuck it in the mill and a hour later looked like this.
Took a file and trimmed off the burs and smoothed it out a little. Then installed the pcb on to the cooper using Fujik glue with a little artic silver 3 compound mixed in.
Ended up being about 2.5mm with the pcb on top.
I then proceeded to reflow the XML-U2 led on to the copper aluminum pcb. I was expecting this to give me trouble but the new copper took the solder well and reflowed easily.
Installed it into the brass pill with some fujik thermal glue mixed with a little artic silver 3 thermal compound.
Soldered the output wires and she’s good to go.
Installed the pill in the Xiaozhi customized host. This has a 2800ma amc7135 driver with two extra amc7135’s and Dr.jones Luxdrv 3.0 with a little adjustment to the pwm values. The grooves in the head is machined on a lathe and the grooves down the side of the tube are all ready present on the Xiaozhi. I used a ball end mill and followed the same pattern down the tube taking around .010” off revealing non anodized aluminum.
Here it is beside the factory Xiaozhi.
I have always liked the cool shots some do with their knifes in the back ground. Gave it my best shot even though I’am not much at taking pictures.
Here’s another showing a little more detail.
I have really thought about doing a 1000 post give away with the second Xiaozhi after I do the machine work. I will not be making another one of these copper pads though. Much easier and cheaper to wait for Nitro to get his hands on the real sink pads.
Excellent job, oh to have a lathe…even a little one to do this kind of thing. But then, I don’t know how to use a lathe…perhaps I’d keep all my fingers in learning how.
This is nice, love it. Would have liked to see your copper base replace the entire pill
What some people do to avoid spending money. Lol. That was one amazing bit of work around. The pics are so clear I’m not sure people realize just how small the work area was. Wow!
I think from OL mod like this that the slot is 1.6mm or 1/16'' in width. Pictures in this case really dont show how small everything is. Again this is a really nice, time consuming mod.
I often thought if this was doable, possible. Nice work!
I just did a little more mod'ing on my Xiaozhi last night, nothing like this though. How does it run with the 3.5A in that small host with a SinkPAD equivalent? Are you able to actually get 3.5A and can it be run on high very long?
Last night I added 1 7135 to bring it up to 3.15A, and also programmed a custom Luxdrv from Dr Jones. Im using an XM-L2 T6 3C on a standard aluminum star. It did get measurably brighter, at 785 lumens at 30 seconds, but at about 1 minute, it shuts off, then 10-15 seconds later comes on for a short while, then shuts off, continuing this. It appears to be a straight, simple overheat safety shutoff but I didn't think the luxdrv had that in it. It does get awfully hot. I added 1 copper disc in the pill, Arctic Alumina epoxied in. I'm using a Panasonic 3400 unprotected, so I don't think it's the battery.
It is amazing to have this power in a nice EDC package with a neutral tint, but not sure what's goin on exactly with the shutting off - it does get quite hot .
