Got bored this morning and went to the hardware store for some more brass fittings. Put together this triple p60 light that is kind of cool. Running on 3 18650’s with fasttech one mode xml’s. I simple just soldered the 3 heads together and the rest just screw into the head. You have to turn each on individually. This thing probably weights 3lbs with batteries. I don’t know how but beam is perfect they all funnel into one hot spot. The other little light runs on 1 16340 with a one mode xpg r5 also from ft. I have put a link to the pics, didn’t know how to attach them.
Took another look, and now I’m confused. How does the switch work? Is it just twist to turn on? If so, what sits between the contact at the negative end of the battery and the housing?
yes just twist on and off. the spring keeps the battery held away from end cap until tightened down. the springs are the outside spring off of the dropin.
