I just bought some NV1010s from Convoy to test them out. They haven’t arrived yet, but I have high hopes for them, and I’m now looking for a suitable host.
What driver should I use, what drive current would be best, and what kind of lens or reflector would you recommend?
I’d like a more compact light that I can actually carry around in my backpack. USB-C charging would be nice, too.
In general, I prefer throwier lights over floody ones, but I know that, because of physics, I can’t expect too much throw from this emitter. So I’m okay with a somewhat floody beam, maybe with a TIR lens or an orange-peel reflector. However, I don’t want a mule.
I’m thinking of something like the Convoy M21K or M21H:
or
However, I’m not sure how efficient a TIR lens is with such a much larger LES.
I also don’t need a hot rod. I personally don’t see much point in insane lumen numbers if they can’t be regulated and sustained for a reasonable amount of time.
at least a few minutes, rather than just a few seconds.
I have one with a NV1010 and the beam isn’t too nice, it has a very small dark spot in the center followed by two rings. The inner Ring is a little bit brighter than the outer one, but not by much.
And it’s overall quite floody, realistically usable for something way under 100m of distance.
There’s nothing impossible, you can put it into most hosts, but some may be more difficult to mod.
Any 3V driver under 60-80A is good
The easiest mods are with M21K/M26E/M21J, and all other hosts that use SBT90, but don’t expect a good beam from NV1010 in thrower reflectors.
So far I’ve installed NV1010 into M26E, L7, S3, T6 and I plan to make a T5 mule with it.
