How about this UI?
How does this sound?
1 quick click to moon
2 quick clicks to low
3 quick clicks to mid
4 quick clicks to high
1 long click to high w/ turbo timeout back to mid
that's better.
Not keen on step downs going to mid, too much of a jump. I think “use of the flashlight” as in what will you use it for and tailor the UI to that is the best way.
What type of light is this? Size, output, battery, etc.?
Also what type of switch? I’m assuming it’s a single switch mechanical?
If so, then isn’t this just a standard cycle through the modes (half press of the switch either forward or reverse clicky).
Just going:
Moonlight - low - med - high?
Sort of ok on a low powered small (AA/AAA) light, but very annoying if you use high mostly.
With this type of UI I think it would be very nice to be able to user configure the ordering, either from
Moon - L - M - H
to
H - M - L - Moon
That way there would be no need for memory as the user could choose if it started on high or low.
That said I still think such a UI is pretty pants in terms of what an end user actually needs a light to do.
I find that people either use the highest or the lowest modes the most and the ones in the middle less so, unless the UI is so annoying that getting the right mode is more effort than it’s worth.
So with this in mind, you really want a way to pre-select/choose if the light turns on in moonlight or max. Then the user has better control and you don’t have to remember which mode you used last.
Personally I’d like to see a more advanced setup. I like the idea of 2 groups of modes, one with head tight and one with the head loose.
Head tight has no memory and is Turbo - High.
Head loose is no memory and is Moonlight - Low.
This way you can choose if you want bright or dull modes before you even turn it on. And usually any mode you want is just one click or a head twist away.
With your UI of
Moon - l - m - h
If you are on Low and want Moon, you have to cycle through all the modes to get to it.
With regards to step downs. They should be there to make the light usable, rather than to make it dimmer by a large margin.
Assuming this is a high output Li-ion light.
Then Turbo should be the highest output you can get from the LED & battery source, maybe direct drive, or 3-4amps.
The downside is lots of heat. So the step down should simply kick in to then offer the highest output the host can handle for sustained periods. Dropping to Medium or the mode below is often too much of a jump and to reactivate you again have to cycle through all the modes (the Eagle Eye X6 SE for example, which makes it f’ing annoying when out walking, so much so I don’t use for that any more).
Turbo = the highest out the setup can produce
Turbo step down = the highest output the host can handle for sustained use
High = good output, much much lower amps, ideal for indoor use or long term on time in an emergency
Moonlight = as low as you can get it to preserve night vision and be less instrusive.
Low = reading/map work/close up stuff
Don’t really like quick clicks for modes that will be used often.
Miss and match will occur frequently, especially 4 clicks. If 4 modes (moon-L-M-H) I prefer (from off):
1 quick = moon
2 quick = high
hold to change to next mode
3 quick = other group (beacon, click for change mode, strobe then sos), 2 quick from here to previous standard mode.
If want to have turbo, using head loose = standard, head tight = turbo.
Sounds not good :smiley:
- 1 quick click to last used mode > quick click > next mode (order is low, mid, high)
- 2 quick clicks from off to high
- press and hold (from off or any mode) for turbo
- 3 quick clicks to enter blinki modes and then 1 quick click circles from strobe > beacon > sos, long press to exit blinki group or even longer press to power off
  • long press (from any mode except blinki group) to power off
:wink:
I’d prefer cycling through the modes, I hate having X amount of quick clicks or hold for X amount of seconds. Its really confusing with dozens of different lights all with different methods of changing modes.
I don’t think it’s that bad, it’s just a normal run of the mill UI.
Buy a C8 host and chuck a Qlite with the 4th star soldered and you get pretty much this UI, albeit with memory.
It’s just not very imaginative or the best UI for the best user experience. It’s just a simple UI to cater for 4 modes via a single mechanical switch.
And there in lies the problem. A simple design such as a single mechanical switch works well with simple UI’s and limited modes. But larger or more complex UI’s need alternative solutions.
Electronic switches offer a solution as they can understand a click and hold, or different durations and speeds of clicks. e.g. An Olight S15, click and hold = moonlight. Single click is last used mode. And double click is MAX output.
All available from off. Despite being a single button you can turn the light on in 3 different ways.
A mechanical switch alone simply can’t do this.
Probably my favorite, but like to change for my own liking.
Counting the number of clicks is the worst UI possible !
I prefer : normal clicks cycling from high to mid to low
1 very long click for moonlight
2 quick clicks for strobe + 2 quick click for SOS when on strobe level
Best to use a side switch with a tailcap switch.
I agree.
Thats why I prefer to have a tailcap switch ;)
From OFF;
  1. Long press to Moon
  2. Short (you may call it quick) press to memorized mode
  3. Double click for Turbo
From ON:
  1. Long press to OFF
  2. Short press to cycle through modes, from low to high.
  3. Double click to Turbo
No blinkies if possible.
well,everyone has a choice,especially for different type of lights for different useages.
For EDC, I like it to be:
5-7mAh at moon. (when I have to go to toilet at midnight,no hurting the eyes)
100mAh at mid. (walk down a dim street )
750mAh at high.(some pathways without lights at all.)
without the h
Yes,Cry mA
How about long press, one click, two clicks and I get to pick the levels myself.
