How can I mark some Carlco TIR's to differentiate between them?
I've just finished up a build for a customer using an optic in place of the reflector and I've made it so its really simple to swap out TIR's, I'm including an elliptical, spot and flood lens so the light will work for a variety of applications, he ca just pop them out when needed. For him with only the 3 it wont be an issue to know which is which since the spot is clear, the flood is rippled and the elliptical has straight flutes running across it but in other builds and for around here is there a way I can mark the lenses that are all visually the same exact thing? (there are several pattern lenses that are frosted and I also have two that are rippled that are different beam profiles). I've tried putting a sharpie mark on the inside of the lens but that shows up in the beam, is there anything that'll work as a way to mark these things?
Marks on the edge. File a rough spot. 1,2,3,4 marks for different angle lenses.
Which carclos are you using?
Baggies.
You could use a clean pencil tip soldering iron to burn shallow holes on the edge or somewhere unlikely to show up in the beam.
Paint the bottom of the legs in different colors. Got a wife? If so, use her nail polish.
Yeah use the little baggies with ziplock and mark the baggies.
You don’t want the optics just sitting collecting dust or getting scratched.
I use baggies here around the house (cause I bought all my lenses in bulk anyway) but I’m thinking I’m going to be carrying some of them around, I have one of those single waterproof battery cases that they fit well in. I’ve finished up a build using an old Fenix E20 as a host and its my first (other than the fenix P2D I built for the customer) that really allows easy swapping of the optic on the fly so I want to utilize that feature whenever I can, I really like the elliptical one but its not good for everything and the other few I like best are all rippled so other than trying them to see I’ve gotta find a way to tell them apart.
The idea I really like so far is to use several different colors of glow powder, mix up different colors of glow epoxy and “paint” it on just the bottom rim (thats below the LED’s lens anyway) so they actually glow slightly in different colors. Should also look pretty cool in the light when its off and shouldnt effect the beam.
Filing tiny notches in the OD is the only thing that won't be visible after assembly. Or, if you want it identifiable while still in the light paint the bottoms of the 3 legs different colors (make sure to use something that won't be affected by thermal paste - so Sharpies are probably out).
Well there you go, that’s actually a pretty good idea.
Also leaftye’s suggestion of painting the legs with nailpolish.
Both good ideas.
