How Can I tell if my C8G is DD or Regulated?
Is there a way to tell? I understand there were two drivers for the SST40 version?
Get two similar batteries, one at 4.2V and one at 3.7V. Then find a 500lm-ish mode, power it with either battery, and compare the brightness.
If the brightness is about the same, you’ve got a regulated driver.
If the 3.7V is much dimmer than the 4.2V, then the medium mode is achieved by PWM on direct drive, which drops quickly with lower battery voltage.
A 500lm-ish mode is chosen to rule out FET+1x7135, which does regulate low modes, but not as high as 500lm. Beyond 1000lm or so, both driver types may drop out of regulation at 3.7V.
which driver do you have? can you either look up what driver you ordered, or take a pic of inside the light se we can see it.
If you have FET driver it is basically DD, with pwm for lower modes, if you have a buck, linear, boost driver, then it is regulated. there are combo drivers, regulated fet, it regulates low modes, but high modes are DD
