i got a old battery pack from my friend, and it might have a dead cell or something since it suddenly just lost battery life, but it still works and can run a laptop fine. So is here any precautions i need to take to dissemble the pack? for example, discharging it, unsolder everything, etc? i already have the cover off, it is a Toshiba pack with 6 red 18650s
Red 18650’s might be made by Sanyo.
Just remove all cells, at first disconnect + and - of pack from controller PCB, then disconnect separate banks from each other (usually they’re made of 2 or 3 parallel-ed cells), then disconnect individual cells.
Just tear the metal tabs off and try not to short the cells out. There is no trick to it. You don’t have to discharge it.
alright thanks for the advice I will update you guys how it goes
Good luck! :) If you need help identifying the batteries just post.
I will take you up on helping!
I tore open a 6 cell laptop battery for an OLD fujitsu.
It said “Made in Japan” on it
Batteries are wrapped in a red semi transparent wrapper
There is some text on the cells themselves that shows;
B
HD2FHH2
053851
0,1,2,3,9 (one of these on the bottom skipping one line bellow other text. I have 6 cells and 2 of them say “9” here))
Do they look like these? Also on the positive nipple is it a red spacer or blue?
yup thats them! wow that was fast!
white spacer tho
White spacer means they’re Sanyo UR18650A.
Rock on! Thanks for the valuable information!
Doesn’t it says “SANYO UR18650A” on them btw? It should, it’s just very hard to see (and very hard to take photo of, obviously…
mine do not. the text is only what I said earlier, and unlike your battery, my text wraps around the circumference…. I wonder if it is still the same?
also as an added (newbie) question, one of the six batteries had the red wrapper ripped off by accident. Is it still safe to use or should I dispose of it properly?
Hm, mind showing photos of yours?
And, the one with torn wrapper: just wrap it with electrical tape or heatshrink and you’ll be fine. Wrapper is there just for isolation (because whole body of cell is negative contact).
Here you go, note the “F” mark on the tail of the battery.
Also, these have not been cleaned up from being dissassembled as you can plainly see.
Also, I have another battery pack from the same computer (but only 3 cells).
The pack has a rating of 3800mAh. How do I find the rating of each individual cell?
3800mAh in 3-cell pack? That’s quite weird… That’d be either 3 cells in parallel, so 1266mAh per cell (which makes very little sense), or there’s something messed up with the mAh rating.
And yeah, they’re Sanyo cells, and there MUST be some kind of engraved writing on them - try shining on them with a low lumen flashlight from the side, that’ll make seeing those hard-to-see writings much easier.
and looking online for the part number I can only find either 2200mAh or 4400mAh…. odd indeed
tried shining the light on them and nothing else is there.
the lettering shown is on the metal part of the battery and can be seen through the transparent wrapper
okay, just opened that one up……
despite being half the size (physicaly) of the one I got my 6 18650’s pictured above out of…. this pack too had 6 cells, weird!
also, the label on the pack reads;
Lithium-ion battery pack
Product No.:FPCBP50
10.8v 3800mAh
P/N CP112055-01
Fujitsu Limited
Made in Japan
Okay so even at low voltage (low as in not being used or charged in about 4 years) I got a reading of 2.84V on four of the cells and 2.94 on the last two cells making a total of 17.24V
The cells were arranged in 2 rows of 3 cells but they were all connected to one another.
What gives? (perhaps I don’t know what I’m doing haha)
6 cells with 10.8V means it’s 3S2P config, so they’re 1900mAh each. Must be quite old pack.
at least 6 years old! what is 3s2p? and how did you get 1900mAh?
I smell a good learning comming on!
