how hard can you push a wavien xp-g2 with active air cooling?
So I am looking at buying one of these.
http://www.wavien.com/shop/cree-xp-g2-rlt/
and putting it in a alloy custom host with a hollow core containing the copper heatsink and some 20-30mm fans surrounded by the battery tube… ie it would look like a over sized revolver drum…
then on front a 75mm asperic.
Question is… with a large block of ported alloy surrounding it and active cooling on the heatsink fins… how hard could you push the xpg2 ?
Am i better off buying elsewhere or do wavien mount their leds well ?
thoughts?
I dont know but that is not an XPG-2 in their picture.
Hah ! :frowning: all my plans keep getting wrecked.
What ultimately limits the output (regardless of cooling) is the tiny bond wires to the LED chip melting. You can only put so much current through those wires.
Hy,
i think it would be better to take the bare collar without the mount: Sample Collar
Tests showed that the XP-G2 can be pushed to about 7A but from ~6A it produces almost no additional brightness, just heat. I think 5.5-6A are safe with good cooling and direct thermal path.
Regards
Kenjii
Just thought I’d post this here, this is the first pic I’ve ever actually seen of a real (name brand) Wavien collar.
Hy,
i have the small one in my Blue Star :wink: Really hard to adjust. The increase in surface brightness is not very big when used with high currents (5A+).
Regards
Kenjii
I notice in their lights they leave the dome on, perhaps the wavien collar works best with a dome-intact emitter?
Their datasheet link that specifies XP-G2 opens up to describe the XM-L.
Is the wavien collar beneficial to anything else than an aspheric lens? as in wavien only and normal glass lens?
For sure it ain't XP-G2, looks like XP-G1
Do you suggest that the percentual surface brightness increase caused by the Wavien collar is less for higher currents?, interesting
I think that would imply that the wavelength conversion in the phosfor layer gets saturated, in other words, that a significant part of the fluorescent molecules (how the word phosfor layer became common I don't know: it is fluorescence what happens, not phosforescence) are still in the excited state when a new blue photon arrives.
This should happen without collar also, ah I see, does that explain the tint shift to more cool white at higher currents?
(slowly learning... )
You see this is why i ask before spending money!
Im just a bit concerned about mounting it myself as i do not have lightmeters and not only do the x and y but also the z axis adjustments that would matter… as I’m not sure at what height the focal point of the collar is located i was more inclined to allow the makers who should be experts assemble it. …
Anyone know exactly where the focal point would be… ?
At least if i mount it myself i can have a hole drilled in the star for direct heat path. Given that the wires on the led melting are a concern I’m considering copper heat pipes off a pc main board wrapped around the exterior of the collar as well and prehaps some low pressure extraction rather than pumping air onto the back of the heatsink… if i set it up as extract i could use air filters and oversize the holes through the pill for the wires to create aditional cooling…
Thoughts ?
You can achieve more throw with a slightly bigger aspheric lens and less amps, in a less bulky package too, than with what you are proposing to do here. IMHO :-D
Comfy posted some really good pic’s of aiming his DIY W. collar, I dont know how much data they would give you but might be worth trying to find and see, it looks like its not to hard to focus on the X,Y axis, to set the height are you planning on trimming / sanding the bottom of it or how were you gonna do that? I’d probably just leave the height (Z axis) however it sits down on it stock.
Edit: Here it is, Post #14
I’ve been thinking about this too, Wavien Collar vs. domed and dedomed emitters. Dome matters?
And since in their website there are small, medium and large size of Wavien Collar, does the larger Wavien Collar reflect more lights back into the die, therefore making more difference (more intense)? Wavien Collar size matters?
Hy,
i don´t think that size matters in this case because the light comes out of the collar at the same angle on every collar. Reflectorbased Setups won´t benefit from the collar, as it collects the light that would be wasted and backprojects this to the die. So no benefit with reflectors as these already use that light.
Greetings
Kenjii
Hmm… then why do they offer collar with various sizes?
Green board around emitter is gen 1(XP-G/XM-L), silver board around emitter is Gen 2 or *2 (XP-G2/XM-L2)
As the above said you can push them pretty hard but at a point they make more heat than light…with that copper heatsink and fans moving the heat out faster it is possible to push them hotter longer but too much current no matter the heatsinking will burn out the lines going to the emitter
You can build something like that…get a XP-G2 on a copper noctigon, epoxy it on a small chipset copper fan and viola
RMM sells XP-G2 on Noctigon/sinkpad
You will have to get the waiven collar from above…but you DON’T have to spend $70 for something like that…daggum
As far as i know are the collars mostly used in cinema projetors. I don´t know how large these or the light-engines inside are. But i read in specs somewhere that the opening angle is on every collar the same. Perhaps its due to better heatsinking inside the collar. Just speculation …
