How hard is it to reverse-engineer a driver?.......
For instance take a typical 4-mode hi-med-low-strobe driver. Is it rocket science?
:student:
Ok forget multi-mode complexity.
How about a 1.5V AA single-mode driver with boost?
:partying_face:
There are 2-3 different 3-pin chips which do that. Circuit diagrams are all over the web. So… not much to RE.
You can even buy those chips in 10pax or even 100pax from AX.
Anyhoo, just goggle around, should find something.
I have reverse engineered several. From working to Not working.
Wow. Here I was thinking reverse-engineering any driver would require me to stay at least at a Holiday Inn once.
It follows that even a caveman like me can do this too I bet.
:laughing:
O:)
Reverse engineer? To what end? Repair, modification, duplication, enhancement/modding?
Most drivers are pretty simple, a few ICs, a handful of discrete components, and the PCB. The functionality they are used to implement pretty straightforward as well, and various relevant details can be inferred. The challenge is that those ICs are black boxes.
A boost driver will have an boost controller (external FET) or converter (integrated FET) IC. It may be too tiny to have meaningful markings, at least on the top side. Or markings may be sanded off. You’ll probably be able to identify its function, and what most of the pins do, but you may not be able to identify the specific manufacture, product family, or part, and some nuances may go unnoticed without access to the documentation.
A multi-mode light, or a single mode light with low-voltage notification/shutdown probably has an MCU. The firmware though may be protected from snooping, and even if it isn’t, it takes a bit of work to “decode” it.
“The challenge is that those ICs are black boxes.”
(Duplication to answer your question.)
Ahhhhh. I thought so. It sounded too easy to take an existing driver, take it apart, and reverse-engineer everything that went into it it so that one essentially gets a clone. And I do mean a precise clone not just a relatively close one.
From what you’re saying I would venture that sometimes (maybe most of the time) it’s a lot ‘easier’ per se to build a driver from scratch than to copy what already exists.
The short of it appears is that there are too many inherent variables per particular driver that will determine reverse-engineer difficulties : some are easy, some are not, IOW.
actual reverse engineering may require firmware creation
but you dont; need that if you just want something standard
available chips do that already
you may have to change or add parts to a ‘reference design’ to set light levels
minor stuff
wle
Hey, it's really easy to reverse engineer most drivers on a schematic level even if the ICs have no markings. This is because there are only so many driver topologies around. Are they any you have in mind?
The more difficult part is reverse engineering the firmware on the driver if it has any. However, it's not too much work to write your own (simpler one). :)
I have an apparently no longer made 1 x AA 1.5V single mode approx. 12mm boost driver that impresses the hell out of me in every aspect.
IOW nothing out there that at least I’ve come across so far remotely beats it. And I’ve come across aplenty.
That’s why I’m suddenly interested in reverse-engineering.
:student:
Do you have any links to it, or otherwise, could you take a bunch of high solution close-up images of it on both sides? Should be pretty easy to reverse engineer, esp. if it's single mode. Likely uses a standard boost converter controller with a few passives around it.
IDK y u don't just say wth u r trying to say w/o using acronyms like IOW... But u r prolly OTP. Instead of IOW y don't u just say so.
So IOW.. just say so . Just sayin'
word
IOW what UR trying to say is U don’t like IOW butt if YDK then certainly IDK why YDK so if YDK then IOW IDK either why I use it sometimes afterwards to clarify what was already pretty clarified. Maybe I’m trying to ease into my franks being blunt about things cause Frank is my middle name and I can be sometimes too Frank I guess. IDK.
:beer: :smiley:
wtf?
Well, if it’s single mode, you don’t have to worry about firmware at all. That means you’re back to it being dead simple.
Ok then, how come if this great driver is so dead simple it isn’t being duplicated en masse in a lot of other AA drivers out there? :money_mouth_face:
I would think if something is great, simple, and as cheap to make as lesser drivers it would’ve been Chinese-copied in a heart beat.
IDK. WTF IOW. IOW maybe Boaz can chime in here?
:student: :beer: :laughing:
BTW LOL = :smiley: in case I lose anyone here.
And beyond all the obvious my IDK scratching me head here really is this:
WHY are there to this day so many sh*tty drivers still being mass produced when really great (simple to copy) drivers are out there?
It's really easy to design a 12mm single-mode AAA/AA light driver, even one with decent power output. There really isn't a need for copying or duplication. Anyway I'll be happy to help reverse engineer it if you have some good quality photos of the board.
I’ll see what I can do, Lone. PM perhaps coming UR way.
You can use a bevy of these ICs in parallel if one’s not enough (ain’t gonna list them all).
Most cheapie 1×AA lights use a variant of one of those chips to boost the cell’s voltage to drive the LED. The smaller the inductor, the higher the LED current… to a point.
So a “stack” of these in parallel, output rectified through a small diode and feeding a cap so individual pulses don’t end up fighting each other, should power an LED (or parallelled LEDs) to a reasonable current.
I might just get a bunch of these chips to burn off “dead” AAs and act as a nightlight…
Think the YX8018 mentions (can’t read Chinese, so am really guessing) that the chip itself can handle 8V as its absolute maximum, but don’t count on its internal FET being able to handle high currents pinging the inductor. Just saying it can probably handle multiple AAs, an LFP, even a 14500 without going “pouf!”, as long as its maximum current ratings aren’t exceeded.
Otherwise, just go discrete and build your own Joule thief.
