How many lights total have you modded ?
How many of them are in the normal circulation of lights you use ?
about 8
broke about 3-4
one is in circulation now
Hmm . . . completed mods . . . about 5 or 6. But does my lawnmower count? (The mower is still not done though.) One in circulation (well if I find it again!).
-Garry
I basically mod all my lights... Often several times.. If I count with lights I have modded several times (a significant change), Id say 100-150 lights depending on what you consider a mod. I have lost count a long time ago so I don't really have an exact number...
I don't have any shelf queens, so all are in circulation. I do have a few lights that see little use though.
Numbers like this does not say much though. One special mod that takes a lot of mechanical work, thinking, testing, part browsing, and maybe some trial and error can be more time consuming than 30++ mods which is just a simple driver/emitter swap..
95% of my mods are just simple basic stuff like driver swap/mod, emitter change + minor tweaks.
Edit:
I must add I have never done the same light in a similar way twice. I always have some larger/minor changes. That makes me learn more... :)
2 dive lights very heavily modded
6 bike lights 2 emitter swaps 3 complete reconstructions
5 Solitaires all 7135 mods, one 55mm 10280 shorty
2 AAA Minimag shorties
3 AA Minimag shorties(working on #4 now) 2 singles, 2 triples
2 Technalites(1 AA but now 16650, 1-8 x AA but now 10x AA nimh 3 x xre
1 4 x D P7 now 3 x D with dummy cell
1 Utilitech AAA now aspheric dd xre 10440
1 TF Mini 01 driver swap
1 dual headlamp elf mod
As far as I know they are all working but for 2 of the bike lights which have the emitter pcb’s taken out.
Edit- and one ray gun w/ laser sights
Somewhere around 8 about half of those were simple 20-30 minute mods.
9 In progress, 7 of those are waiting for parts and 2 are me hoping for a warmer day so I’m not shaking trying to manipulate tiny components.
3 more waiting on receiving the cheapo flashlight that will most likely be a host.
I don't consider myself a modder in the truest sense of the word but have done about 30+ lights so far. Mostly emitter & driver swaps . The little 1.99 wallbuys zoomie is one of the only lights I've actually modded the shape of the body, other than boring out lights.
Hang around long enough ....and you'll find yourself with a file in one hand and a bad ebay light in the other.
Ummm.... All of them? I think the only lights I HAVEN'T modded are my UltraFire M5 I got through the DX slip-up a couple of months ago and my King clone. I don't have a count of course... They either end up with a swapped switch or a replaced tailcap boot or a replacement driver or a new emitter.
most of what ive recieved tbh.
dunno between ten and twenty maybe? most are simple driver and emitter swaps, quite a few are host kits, do they even count as modding?
I got one light yesterday that wont be modded and has suprised me in more ways than one. ……many will be aware of that one, so more on it in another post.
Somewhere around a 100, not real sure. I have never had but one or two lights that I didn’t mod. Even the little Maglite solitaire’s don’t escape being modded. I would say at least half, would have been simple driver emitter swaps. I racked up quite a few mods to Maglite 2 and 3 d’s that where quite extensive and took some time to build. Quite a few cut down 1 AA mini mags went through my chip maker. I’m not really sure, it be hard to count from the start of all this, back to the 1 watt luxeon days. :~
I’m waiting on OL to chime in here, that would be interesting.
I’m sure his probably going to take the trophy for the most mods done. :bigsmile:
As keltex78 suggested, it might be easier for some of us to list the lights they have not modded…
I have not modded my Solarforce MPP 1 & 2, & I’m yet to mod my BTU shocker, but it will find it’s way onto the chopping block when I stop pinching the Noctigon’s that I ordered for it for other lights….
My next mod will be my “Courui” AKA Big Head Thrower - will have some time over xmas to do the mods, with before & after comparisons ![]()
Two completed, 1 pending.
Every light that I own that doesn’t have a glued head |(
I have done about 6 lights and going to complete 2 more. It is my new years resolution to get them done by February. found some pretty cool led lights that are long lasting as well.
Lemmesee…a mod to me is anything from mild to wild that is not original to the light.
At least 3/4 dozen MiniMags, most given away, and all with an LED drop-in of some flavor, and tail clicky added. All brighter than the departed, elegant and expen$ive Opalec kit.
From CPF days…a 3 D cell Mag, Direct Drive, with a TVIL Luxeon III. Old technology, but bright, good tint and a great run time. Changed batteries In November, when I thought it was getting a little dim after about a year of use.
Another 3 D Mag, with Diamond drop-in…On “loan” to a friend who works security, and needed a better light.
A Coppertop 2AA light from the ’80s, with another drop-in. It traveled with me on business a lot of miles before and after adding the LED.
A Duracell plastic 2 D Supermarket Special, with a no-name LED. It has the best reflector design, and is my car light.
A Fulton GI Angle-head light, with 3 watt LED.
I modded the 3 D Mag, and said “There has to be a better way!”
There is!
JUST BUY What fits your budget and needs! :bigsmile:
They are ALL still in use/in my rotation.
Give or take, probably 40 or so. Ok, probably more than that. And the .50BMB for O-L’s build contest. And the much more difficult than need be laser module mount in the Brinkmann Legend LX.
I have NOT modded my Tank007 E-06 or the stainless 2AAA from Ric. I’m pretty sure everything else has had some work. More than 30 of mine. A growing number of some friends.
With several more in the que…
And yes, even my Avatar light , the Texas Poker, has been worked on. ![]()
Define mod? If you say, to do any sort of changes to a light that is not cosmetic, and this does not include changing P60 modules in and out, then I would have to say at least 6. Of those 6, I have given one away, and one of them has replaced my T20C2 (v1) as my single cell throwy light.
I have 3 builds that are in progress.
Literally, more than I can keep count, as far as modded and who knows how many are still in circulation? It's scary to think about it. We are talking about 5 years here, all told, between here and CPF.
There’s a lot of bad-a$$ MagLights out there with O-L’s mark on em, for sure! ![]()
I broke one, so i recently modded it as my first one :party:
I use it many times, it’s a xtar b01 with nanjg105c 2,1A and a xml t4-7c led.
