How much current can a Nanjg style driver handle? Is there a limit as to how many 380mA chips can be added before something on the driver fries?
I'm pretty sure I've read here somewhere of as much as 5.6A (16 chips total) with no issues. I've run 4.2 with no problems.
I’m pretty sure that space or soldering skill would be the limiting factor. With the 7135 chip, current goes into the wide pin at the back and out the leftmost pin at the front (which connects to LED -ve) Unless solder connections are bad, I don’t see any reason for limitations until much larger gauge wires are required.
Thanks. I’ll be using them in a light where space will not be a limiting factor at all… but soldering skills probably will ![]()
Sky's the limit. I've designed rivers that use 32 AMC chips. The limiting factor is each individual chip; they handle 350mA to 380mA each. You parallel them to reach your desired total output. Theoretically the limit will be how much current the PWM signal can handle to turn X number of chips on, or your power supply, or your LED wiring job and so forth. Hundreds is possible I believe.
I've done lots of 4.2A Nanjg's, but seem to get into issues after that. Think the two-on-top stacking is a bit more involved. For example, I had a 4.9A Nanjg (two that are 3 high) sitting around and can only get 4.66A or so tops out of it - think this means one 7135 is not functioning, but everything sure looks fine.
Those big SRK drivers or the 7135 farm boards are probably much better than super stacking.
Consider using Matt’s 12 or 16x 7135 slave boards (never needed to use one so can’t remember exactly how many) over stacking super high.
I have had a similar interest too in knowing how much a Nanjg could sustain without exploding. So far i have had 16 - 7135s on a test unit, (got 5.53 Amp draw on a Dedomed XM-L2 on Noctagon in a test) which i will be using four of these in sync to power the 4-DST monster Thrower i have been slowly working on.
Stacking won't work as well primarily because of heat issues. Your current will sag as the AMC chips get hotter, and stacked chips are effectively acting as heatsinks for each other. All they are doing is heating each other.
If you want big output power you should definitely look for PCBs designed to take your required number of chips natively. Definitely avoid stacking more than 2 chips, none if you can help it.
