Is there a way to combine the charging circuit from one driver with a new driver? Like the driver from a bd06 combined with an fet+1 driver?
Or
Is ther a small charging circuit out there that I could implement into a light? Maybe I could take apart a one bay xtar charger and use the circuit? If I had to I could move some components around to make the circuit smaller.
Has anyone thought of this or even maybe tried it?
Ok. It looks I could manipulate the board if there a light with some space. Now, if I connected this circuit to the battery with the driver connected as well, do I need some components to protect the led from the reverse charge? I guess this is probably a hard question to answer as each driver works differently. Some regulating on the high side and some on the low side.
I think I will order one of those circuits and play with it. Probably the best way to get my questions answered
The LED will just do nothing if you put the battery in backwards.
But other components on the driver board may fail, unless the driver has protection against reversing the battery
I think it would be possible to take of the components and reflow them onto a custom board. There’s not much there… Should fit on 16mm board? This would open up the door to mod some lights with charging circuits and low output. I could always add my preferred driver and ignore the charging input, but if there’s aport there seems it should be used. Just my opinion though.
Hmmm… I hadn’t thought of keeping the charging circuit outside the light. Then it could use a dedicated charger specifically for the light. This may be helpful.
