How to mark drop ins to distinguish which is which?
How are people marking their P60 drop ins to distinguish which is which? I have a number of drop ins from different vendors and many of them don’t have any markings to tell me their spec’s. So I want to mark them. I tried using a permanent ink marker (sharpie) but over time the heat bakes off the markings. I thought I could engrave the brass section on the side with an dremel tool. But is there an easier way to keep track of these? Thanks
I don’t have enough for this to be a problem, but solarforce uses actual labels (from a label maker) and color codes them.
I only have 3 drop-ins from different manufacturers and thankfully they’re different in color and appearance.
In your case, engraving would be a nice option.
I have struggled with this for a while now. Sharpie does not stay on and I have about 15 home built dropins and maybe 6 commercial dropins. Can’t use the normal thermal printer labels, they will turn black in a hurry. Love the Solarforce metal film, but have no way to print those.
I have been using a dremel tool with a diamond tip bit. unfortunately it is very crude because the space is so small and my hand shakes when i try to engrave but I put XML2 then the max volts 8.4 or 4.2. Takes up the whole side of the brass base. But since I have a dozen of these drop ins it helps to keep them straight.
I use a label printer, or you could just print a small label on paper and stick that under clear adhesive tape.
Just have enough hosts for the drop ins and chuck the rubbish drop ins (or sell them). :wink:
Then maybe keep a spreadsheet list of what is in each torch.
At the end of the day, the only real thing you need to know is if it’s only 4.2v. But I don’t run anything that doesn’t work on an 18650 really, so not an issue for me.
Being serious, it’s easy to count the number of modes a light has. And LEDs are pretty easy to ID without turning them on. Even NW and CW. And even drivers are pretty easy to spot, e.g. A Qlite looks totally different to a BLF X6 driver.
You have a better eye and knowledge than I do. I have about 12 L2 style flashlights mostly L2M’s but a few Solarforce L2Ps and L2Ts then I play mix and match with the parts so I never know what parts will end up where… I do keep a spreadsheet but I really can’t tell a XM-L T6 from a XM-L U2 from a XM-L2 U2. I can tell them apart from the XP-L Hi V2s that aren’t domed. So I need to mark them.
XM-L2 is easy to ID vs an XM-L. But I too couldn’t tell you what bin a LED is.
But I guess, does it really matter if it’s a T6 or a U2? I know when buying you might want to know, but once you’ve got it, the difference is somewhat meaningless.
What about creating a cheat sheet and just marking the drop-ins with roman numerals using a carbide scribe? The simple straight lines of the roman numerals might make things easier.
you beat me to it.
exactly how and why i do it.
