HS45 Temperature Test v2
Video here
Hi, I decided to make a new test of the HS45 temperature with the fan kind of disabled and monitoring the full runtime of the flashlight on “high”, as some people requested me.
Test conditions:
The room was on normal conditions, at ambient temperature with one window open the entire test.
I decided to put a paper in front of the fan, so the air current from the fan has a minimal impact on the temperature of the flashlight.
The test was performed with the included Sofirn 5500mAh 21700 battery, the flashlight was on “high” mode and the temperature sensor has directly on contact with the center of the flashlight head dissipator (very close to where the LED actually is).
I used this temperature sensor as it is more precise than the IR gun I used last time, because it is in direct contact with the aluminum of the flashlight head.
Sorry for using a Casio as a timer.
I checked on the test very often to guarantee there wouldn´t be any problems. My camera battery died around the middle of the test, but I left my smartphone recording while the battery charged a little, that´s why you can see the camera position change.
Results:
As you could see in the video, the flashlight head got to 68.4°C, very close to the 70°C user u/PiercingTheDarknesss got on his tests. So, the flashlight has a flaw on its temperature control without the active cooling, especially on “High” mode.
Conclusion
I think the temperature didn’t go any higher because the battery could not delivery the full Amps the flashlight required on “High” anymore, the capacity must have been less than 50% when the 68.4°C were hit.
If I am correct, with a higher capacity battery the flashlight could get way hotter and cause accidents. I monitored the entire test and checked it very often to see it anything went wrong, and if it got to 70°C I would instantly stop the test, because there was a risk of the battery catching fire or exploding if the temperature got higher.
Be careful if you own this flashlight.
