If I recall correctly, the ‘pencil’ mod, creating a trace of graphite across the memory capacitor on a driver serves to remove next-mode memory and cause the light to always begin on high again, correct? And simply removing the capacitor and shorting the contacts eliminates the modes altogether and causes the light to always come on in high, correct?
The question I am trying to solve is that of crappy modes in a factory boost driver, such as the Small Sun T620, which has a nice boost driver that is easily modded for higher currents. But the mode spacing is bad and the SOS is almost unintelligibly rapid. Not possessing an inductive reader/writer and accompanying software and training to use, I am left with modes pre-programmed into a particular MCU
So I had an idea. The power a boost driver puts out is at a voltage such that a standard 17mm 7135 driver would be able to deal with without having to employ the zeiner mod. At that point, one could simply stack chips on the 105C to match the current output of the original driver and then wire them in series. In my example, one of RMM’s Qlites with 4 extra 7135s to give it a bit over 5 amps measured. I would then be able to pick the mode group I desired.
Am I missing something? Is my thought experiment fundamentally flawed, or is it worth a go?
The second driver in the chain (the little boost driver) won't know it's being fed by a driver and will still operate the same as it did before. Switching the 105C's mode will just cause the boost driver to boost it back up to where it would be without the 105C.
IMHO boost driver would need to have adjustable output voltage (set to 105C manageable level) otherwise when 105C is off or in modes other than high, output voltage of boost driver might be too high…
I would like to hear more responses on this issue. I want to make a 2xAA light with programmable modes, but I haven’t seen any boost drivers that use an Attiny.
Note just like wight’s 7136 driver you will need to turn the PWM down, in theory under 3khz should be good but just like wights case you may need to go <1k at first.
I went ahead and created a new .sch, this is boost only using the same TI LM4310 (not SEPIC) and runs a 13A, recommended vin is 2.7-5.5, it will run at 2.4 but not at full power. Before I do the board layout please let me know you are definitely interested, this didnt take long but totally laying out a new board will take a little bit of time. I dont mind doing it at all, I actually enjoy that aspect the most, but I have lots of other project’s to spend the time on if you dont for sure need it.
Also, if you’d prefer the SEPIC converter with a 13A I can simply do that for you too. If you dont know what a SEPIC is, its pretty much a lower input range buck-boost, it allows the vF output to be lower than, equal to or higher than input voltage while maintaining good efficiency over that range.
What size do you need this driver to do? anything smaller than 15mm and a SEPIC is out of the question because it requires a 2nd inductor and that takes up to much space…
Looks great!
I noticed there weren’t any links to an osh page or a parts list, are you keeping these close to the chest or do plan to make it open to anyone?
I don’t have stuff to work on PIC’s yet, so I would need a 13a version.
Edit: just saw your 2nd post.
I’m not familiar with SEPIC. I am primarily looking for something that can boost 1-2 AA’s and let’s me program my own modes, but being compatible with 1-2 lions would be a bonus. I suppose 15mm would be ideal. I’m definitely interested, as long as the price is right of course. I wouldn’t be needing large runs of these, just a few.
There are no link’s yet however it is all open source…
I’ll have a preliminary board laid out for your today! Stay tuned. To keep cost down I’m going to do it as boost only (meaning only a single inductor is needed) and run a 13A.
Does anyone know if STAR will run on a Attiny13V? I have ran a 105c with a 13V before but using some really simple code I wrote, not STAR. I believe the only difference is the input voltage (with the 13V being the low voltage version) but I’m not confident, can anyone confirm it works before anyone get’s to far into it?
The ATiny13 (including the ATtiny13V) has been completely superseded by the ATtiny13A. I’m not aware of anything that the 13V can do which the 13A cannot.
I’ll start a thread for this driver here soon. Note this IS NOT the driver posted on TFF, that is a SEPIC, this is a boost only (even tho they’re based on the same boost chip, the TI LM3410).
I’ve been doing mostly physical / mechanical reverse polarity prevention instead of going with a protection diode lately, is that cool or do you specifically want a protection diode? Adding the diode may cause BOD to kick in some (the reason I left it off because of the already low operating voltage).
Also is 15mm what size you needed it to be or what?
Attiny13V is the low voltage version of Attiny13.
Operating Voltage:
- 1.8-5.5V for Attiny13V
- 2.7-5.5V for Attiny13
Speed Grade:
- Attiny13V:0-4MHz@1.8-5.5V, 0-10MHz@2.7-5.5V
- Attiny13:0-10MHz@2.7-5.5V, 0-20MHz@4.5-5.5V
The latest version Attiny13A have pico power feature to replace the Attiny13 and Attiny13V.
Operating Voltage:
I’m waiting on boards, seems to me like OSHPark has really slowed down recently…
I will keep you updated, and if you’d like to go ahead and get components orderd anyway I’ll get a parts list together once I get to my computer today.
