last night i decided to take all my flashlights apart to clean them (all 8 of them, 4 x p60, MRV clone, 2 x HS-801 style lights, and a cheap 4AA light). while i have the tail switches out, i measured how much current they can handle. they range from 2.0A - 2.5A. the one that can handle 2.5A has the marking 1.5A 250V KAN-28 on it. for reference, without using the tail switch, i measured 3.2A from a UF 3 modes XML drop-in. so clearly, the tail switch is the bottleneck here. anyone know where i can get some good tail switches that can handle 3A+ ? most of my switches are attached to 20mm board. nothing expensive please
After much searching, there really aren't many good inexspensive switches. The mcclicky (expensive) works up to 5 amps and a fet based switch can hypothetically handle as much current as needed, but both are very expensive.
Curious to see them. Got a link maybe?
Those are cheap and work really good around 3A. 5A.. time will tell. ;)
McClicky and FETtie are rather expensive. McClicky is about 7$ and the FETtie 50$ or so.
thanks for the reply guys.
@NightCrawl
the one that u link to has the exact same marking (1.5A 250V KAN-28) as the one i have, but mine is made by loongsun not ultrafire. so i guess the difference is the board and the spring. do the board and the spring really make the difference? mine has gold color spring (not sure if it is gold plated) as well. u said the ultrafire ones can handle 3~5A. have u actually measured it?
Just curious, could you measure the resistance of the switch itself?
Thanks!
I will add that ultrafire switch is the one usedin my X6 and it died, it did have 3-4 amps at 12 volts going through it though. ;)
i will try measuring the resistance tonight when i get back from work.
Resistance is key here. How you measure current throught switch? Do yo have spring pressed?
The switch itself could handle ~89A at 4.2V(if we can trust specifications).
@Prometheus: I did. My 3.5A dropin pulled 3.4A with the Ultrafire switch, 3.2A with one from Solarforce, 2.6A with the stock one and 3.5A without tailcap. They've held up pretty well, I cant say anything bad about them.
@okupka: Thats AC. We are using DC, so make that 9A @ 4.2V.. though I doubt that they will handle that..
just though i would add my experience with the few switches that ive tested to high currents:
solarforce switch: they say good up to 3 amps - I have pushed mine past 6a without anything melting although im sure it limits the current a bit.
mcclicky - ran 7.2 amps on it for extended periods and no problems
