I bought a computer - How did I do?
3/3/2013
Intel Core 3rd Gen i7-3770 Processor (3.40 GHz with Turbo Boost 2.0 up to 3.90 GHz)
1TB Hard Drive, 3.5 Inch, 7200rpm
SATA 32GB mSATA caching SSD (I'll eventually install a larger SSD and will continue to use this with the 1TB SATA drive)
16GB DDR3, UDIMM Memory, 1600MHz, non ECC (4 x 4GB DIMMs)
8X Blu-Ray BD Combo (Blu-ray ROM + DVD+/- RW)
AMD Radeon HD 7770
Windows 8 64-bit
$743.20
I passed on the AVA Direct build because this setup seemed enticing for the price. I know I don't need 16GB of ram but it's not an expensive upgrade and it's there for the future. The i5 35xx also would have sufficed but I didn't really have a choice. I'm not a gamer or video/graphic editor, aside from the typical Photoshop tinkering, but I think the Radeon HD 7770 will be acceptable if I do decide to do any of that. I'll install a 256GB SDD myself when I find a great deal, but the current specs will get me through just fine for now.
So how did I do?
What case did you get?
That’s the twist. It’s a Dell XPS 8500 :stuck_out_tongue:
I was originally going to have one custom built from AVA Direct but I saved $400+ with this computer. It’s a refurb from Dell Outlet and I used a coupon. Brand new this setup sells for ~$1400 without coupon on the Dell website. It’s the “Special Edition” white case but that doesn’t mean anything to me.
Just a few minutes ago I purchased this HP monitor for $130 from the Best Buy website. It’s currently $50 off and it’s an IPS panel! I have no idea what it looks like and I can’t find any reviews but I can return to my local Best Buy. I can pick it up later today. It’s the size I was looking for (actually 22”) so it’s a steal if the picture is nice.
Nice!
I’d say that’s a darn good deal.
Let us know how the SSD cashing works out!
Are you using the stock CPU cooler?
Nice setup. Congrats.
Once you get a deal on a larger SSD drive, I would recommend losing the “caching” setup and installing the OS and programs on the SSD and using the conventional HD for your data.
Not sure why u opted for 3770 when the k version is like 40-60 bucks more. If you’re just tinkering with photoshop a 3570k woulda been just fine. It’s cheaper by 100 bucks depending where u shop microcenter. Not sure how much you bought ur msata but you coulda gotten 2x more for same price of a OCZ 64GB synapse. I would just skip domestic brand loyalty and get a 3TB seagate HD for about the same price. I know a lot of my friends just love to buy domestic RCA & WD products. My 2 cents. You did pretty good I suppose, considering budget & mid-range prices means very little today.
a i5-3570K overclocked to 4 GHz or so would not only cost $50 less (incl. price of a decent cooler), but also perform better
but overall, a nice build.
It was a prebuilt Dell. He didn’t “select” any components, nor did have the option to change components.
Dell site has configuration options, not sure about XPS series but their Alienware series certainly do.
Not on refurbs they don’t.
From the OP:
OP did good for his described uses. Should be pretty future proof.
Yeah I couldn’t customize this particular desktop. It’s a pre-built refurb. All I could do is scour the different builds and and find the best bang for the buck according to my needs. I was actually looking for an i5 - a 3570k to be precise - but all they were offering was the 3350P with these refurbs. The 3770 was the next step up. I also didn’t need 16GB of ram but it didn’t cost much more so I figured why not.
As for the 32GB caching SSD, that’s the only size they offer for this type of drive. I will simply use it for the 1TB SATA drive once I get a larger SSD installed, which I noted already. The new SSD will hold the OS and programs. The 32GB SSD can work as a caching drive for the existing 1TB SATA drive. I’m simply using what they’re giving me. If I had it my way I would forget the smaller caching drive and replace it with a 256GB SSD and be done with it already. Those builds were considerably more. This way I can test the computer without spending so much.
Does it has Z68 motherboard? If I remember correctly, only that particular chipset supports using SSD as a caching drive.
+1 as long as the MB is a common variant.
Ah I remember I did a few upgrades on a old Dell myself I think it was the OptiPlex GX260. They really didn’t provide any upgrade options. But through forums I found out it had 2-3 processors that worked that it didn’t’ support. So I went from a single core to a dual one. If you have the dell model number u can look up things yourself and find what others done to it.
I have another older server workstation, I’m waiting for the price to drop to buy better CPUs on.
