I built a small flashlight range calculator and I’d really appreciate some technical feedback from the BLF community.
The idea is to make it easier to understand the relationship between candela, beam distance and usable range. I’m particularly interested in whether the assumptions and explanations make sense from a flashlight enthusiast’s perspective, and whether there’s anything you think should be changed or added.
I understand where that impression comes from. The site is still very new, so there aren’t many hands-on tests yet. I’m currently building that part of the site and more of my own tests and measurements will follow.
But it’s not correct that there are no products I’ve actually tested myself. For example, I’ve been using the Anker Nano 10K power bank since May and published my own long-term experience, photos and charging measurements:
anker-nano-powerbank-10000mah-45w-test
For products I haven’t tested myself, I’m trying to clearly distinguish between manufacturer specifications, independent measurements from other sources and my own experience. I don’t want researched articles to appear as hands-on tests.
And yes, the site uses affiliate links and I also use AI as a tool. But my goal isn’t to mass-produce affiliate articles. I’m trying to build something useful with calculators, technical explanations and, increasingly, my own tests and measurements.
The site is still a work in progress, so criticism like this is actually useful. If something isn’t transparent enough, that’s something I need to improve.
