I normally do not use 18650 batteries. However, I recently got some DIY chargers and bought some NCR 18650B batteries from IMR. They are Pan 18650B. I do have some 18650s that are several years old. I think I had bought some Samsungs. I am pretty sure the Pan B are 3400MaH, but I have no idea what the red Samsungs are.
I did not write down what capacity they were and none have that information on the batteries.
Is there any way to tell the capacities of batteries from anything printedon the battery?
Why would one want batteries of smaller capacities, eg what does a 2600 mah hr battery do that a 3500 mah would not?
You would need an analyzing charger, or t least a charger which showed you how much energy in to figure out the real capacity, especially if the batteries are several years old anyway. If the capacity is not printed on the battery, there is no other way to tell unless there is a model # you can lookup. On a cheap battery, it’s possible that the stated capacity is incorrect anyway. Either way, the capacity decreases over time.
Batteries with smaller capacity are just cheaper to make and therefore cheaper to buy. Not everyone may need the max capacity they can find.
Also some people need high amp draw and the highest mah cells can’t provide it. The new age 3400 cells are good for 10amps, 3000mah cells 15-20, go down to 2000-2500 25+ amps and lg cells like hd2 1500mah 30amp cells. It all depends what you need. If you have a really low .1 mech mod vape you probably need 30 amp cells to be on the safe side
