I mYoffer hom a light,but i dont know if he would appreciate it, being its made in China,ill try looking through Kiadomain and pste the link to see if i can find the powerstar they sell for i believe 45.00,not 300.00.
Sorry I had to copy and paste the whole page I couldnt figure out how to get only thebparagraphd I wanted but youll laugh at some of these claims:Skip to content
FREE SHIPPING SPECIAL - FREE STANDARD SHIPPING WITHIN THE USA WITH ANY PURCHASE OF $100 OR MORE* - USE PROMO CODE FREESHIP100
Gift Cards
MF Tactical
NAVIGATION
866-9-FLASHLIGHT
MF Tactical StingRay – 2700 Lumens Max 4 Mode
Home / 1200-4800 Lumens Max Tactical Flashlights / MF Tactical StingRay – 2700 Lumens Max 4 Mode
StingRay
StingRayStingRayStingRayStingRayStingRayStingRaystingray.4
4.82 out of 5 based on 11 customer ratings (11 customer reviews)
$185.99
The new and vastly improved MF Tactical StingRay with an electronically activated switch sets the new standard in power and quality for a mid-sized high power tactical flashlight.
In stock
Select Battery/Charger Package
The StingRay runs optimally on three 18650 batteries, so you can choose a package with three batteries or six batteries and either a 4-way AC/DC Intellicharger or the more advanced 4-way AC/DC LCD DigiCharger. The flashlight does not come with batteries or charger unless you add a package below.
Add Custom Ballistic Nylon Holster
ADD TO CART
SKU: StingRay
Category: 1200-4800 Lumens Max Tactical Flashlights
Description Reviews (11)
PRODUCT DESCRIPTION
After a lengthy research and development process intended to make the next MF Tactical flashlight the most technologically advanced tactical flashlight we have ever built, we are extremely proud to introduce the new and vastly upgraded 4-mode MF Tactical Stingray. Like all of our flashlights, the Stingray is built out of solid military grade aluminum and is waterproof to IPX-6 standards. This professional grade tactical LED flashlight was designed in the USA and built to the highest quality standards to insure years of reliable service. The new Stingray, like its predecessor, still runs on three high voltage rechargeable 18650 li-ion batteries (sold separately) that enable this beauty’s three highly efficient Cree® XM-L T5 LED emitters to have the capability of an utterly astounding 2700 max lumens of pure white light. You also have the option of removing the 3rd battery tube and running your Stingray on just 2 batteries (with reduced runtime), which reduces your 13″ long flashlight to a more compact 10-1/2″ length if overall size is an issue.
During the design process of the new MF Tactical Stingray, much of our engineering time was devoted to taking all of our experience and knowledge in building great tactical flashlights and designing the absolutely best switch for use on a high end flashlight such as the Stingray. Once you hold this flashlight in your hand and switch it on for the first time, you will agree that we have absolutely nailed it. Inspired by the simple and intuitive switch found on the iPhone®, the new electronically actuated stainless steel switch on the Stingray is by far the finest we have ever designed and manufactured. And function flows from design: just press once to turn the light on high. Then, simply hold down the switch to cycle through the medium and low modes and release when you have reached your desired mode. Switch to our blinding tactical instant access fast strobe mode from any other mode in an instant with a quick double-click of the button. And since the Stingray has mode memory, it automatically returns to the last mode selected next time you turn it on. It has by far the most useful and intuitive flashlight switch on the market anywhere (patent pending)!
The three highly efficient Cree T5 emitters used on the Stingray are so efficient that we were able to engineer this flashlight to run for up to 2 hours on high on a full charge and an incredible 12 hours on low. The thought and hard work that went into the MF Tactical Stingray has produced a tactical flashlight vastly superior to any competitor’s product in this price range. We challenge you to find any flashlight sold by any of our competitors for less than $300 that has even half the power, quality and attention to detail of the Stingray. You will not find anything that comes close, because the Stingray gives you more of everything that a professional user or just a plain old enthusiast (i.e., “flashlight freak”) wants without the $500+ price tag you might expect.
By integrating the anti-roll feature directly into the tail cap design, we were able to eliminate the need for a cumbersome protruding anti-roll ring. Plus, this sleeker design makes it easier to holster your MF Tactical Stingray in its accessory belt ring holster. And what high end tactical flashlight would be complete without the protection and durability that you only get with hard military grade III annonization, which protects your professional grade light from wear and the elements. Finally, integrating an SMO or smooth reflector into the design of the Stingray ensures that you get both the benefit of a bright and tightly focused center beam combined with massive spill to light up wide areas in your path.
MF Tactical is a US company based in New Jersey that designs and builds high quality tactical LED flashlights that outperform and sell for less than inferior models offered by the larger flashlight manufacturers. Every MF Tactical flashlight comes with a full one year warranty (see Terms and Conditions for details) and the high level of personalized customer service that keeps our customers coming back year after year.
At only about 13″ in length and 1-1/2 lbs. in weight without batteries, the Stingray is an amazing powerhouse of a flashlight that will easily satisfy the needs of our devoted flashlight freak fans. The solid and incredibly well built flashlight body crowned with an aluminum “attack bezel” can serve as an effective tactial “deterrent” as well as an emergency glass breaker Plus, by designing the bottom of the tail cap to be flat enough to “tail stand” the flashlight, your Stingray can also serve as a powerful room light in the event of a power outage.
Our newly designed electronically actuated switch is a masterpiece of engineering and the starring feature of the Stingray.
The Stingray comes to you packed safe and secure in a custom gift box.
The output of the Stingray is truly magnificent. The Stingray is the only source of light in this photo.
HERE ARE THE SPECS FOR THE MF TACTICAL STINGRAY:
Brand: MF Tactical
Model: Stingray
Emitter Brand/Type: Cree
Emitter BIN: XM-L-T5
Color BIN: White
Total Emitters: 3
Battery Configurations: Powered by 2x or 3x 18650 protected li-ion rechargeable batteries (sold separately).
Voltage Input: 5~21V
Switch Type: Electronically Actuated Switch
Switch Location: Side
Modes: 4 Modes Controlled by main button
Mode Memory: Circuitry Features Mode Memory
Mode Arrangement: High, Medium. Low and Direct Access Fast Strobe
Working Current: 2.6 amp Total Output, Digitally Regulated
Brightness on Various Modes: 2700 lumens max on high
1000 lumens max on medium
450 lumens max on low
Run Times per Charge: Approx 2 hrs on high
Approx 2.25 hrs on medium
Approx 12 hrs on low
(estimates are with 3×2600 mAh batteries)
Range: 210+ yards
Water Resistance Standard: IPX-7. Protected against water penetration at depth up to 1 meter.
Materials: T6061 Aircraft Aluminum Alloy
Finish: HA III military Grade Hard Anodized
Lens: Hardened ultra-clear mineral glass with anti-reflective coating. Comes with spare lens in box.
Reflector: Smooth Aluminum/SMO Reflector
Weight (w/o batteries): 1 lb, 8 oz
Length: 13.125” with 3rd battery tube; 10.375″ without
Diameter at head: 2.8”
Diameter at body: 1.0″
Diameter at mounting pt: 0.875”
- Offer cannot be combined with any other promo or applied to prior purchases, and code MUST be entered in cart at time of order to receive free shipping.
Copyright © 2015 MonsterFlashlight.com. All rights
X
There’s your solution: have your buddy ask them for a pic, video, or better yet a tour of their factory. Then he will find they have no factory and do not make lights but only assemble them (if they do that much) with parts from all over the world including China. Ditto for those super-duper cells: “Can you show me your factory, or are these rewraps made overseas and what kind are they?”
No point in your doing this yourself you know they will not answer. Your buddy should find that truth himself. You can assist by doing Google satellite/street view pics which will show nothing more than an office at their address, I’d bet money on that.
Or you can just let it go which might be an easier way to keep the peace. But if you do this best not show up with your lights in his presence anymore.
Phil
This is the funniest part :The three highly efficient Cree T5 emitters used on the Stingray are so efficient that we were able to engineer this flashlight to run for up to 2 hours on high on a full charge and an incredible 12 hours on low. The thought and hard work that went into the MF Tactical Stingray has produced a tactical flashlight vastly superior to any competitor’s product in this price range. We challenge you to find any flashlight sold by any of our competitors for less than $300 that has even half the power, quality and attention to detail of the Stingray. You will not find anything that comes close, because the Stingray gives you more of everything that a professional user or just a plain old enthusiast (i.e., “flashlight freak”) wants without the $500+ price tag you might expect.
light junkie, did the guy ever show back up?? Was/is he OK??
Maybe he moved to the next state ![]()
:+1: …. could be. ![]()
Yes i saw him sunday at church he had a much more humble disposition, u still feel bad
Well, it’s good to hear he is Ok and still above the dirt. :+1:
All’s well that ends well and hopefully lessons learned by everyone…… especially him. ![]()
Good to know he’s on good terms with you. More so that he got a better view on everything ![]()
Those who boast will be humbled- it’s how you learn humility and it’s value. So don’t feel bad as it’s better to learn that lesson from a caring friend than to have it happen in a laughter-prone crowd.
After some time passes you might consider private;y gifting him a light which really kicks butt in a box. Don’t hang around for him to open it, just say “I thought you might enjoy playing around with this” and leave it at that. In time he might come back around with a better attitude toward life wanting to know more. If not then you tried to help and that’s all anybody can do. I have only one ‘toy’ which I boast about, but with good reason. It truly is exceptional, but if someone dares to try it can be beaten though not by much (and I don’t want to be within shrapnel range when they try!)
Phil
The really sad thing is that there a people who take advantage of others that are not as knowledgeable. Kinda like the brightest flashlight in the world just released from the military. uses the same amazing LED technology in use by SEALS, ARMY, ETC ETC….
We are all gullible to some degree- it’s only human to want to believe what you want to hear. And there will always be somebody like P.T. Barnum who will take advantage of that if they can. Until we can force responsibility onto the person who causes the lies directly it will continue so as always it’s “Caveat Emptor”. There is value in being skeptical too!
Phil
Phil that is truly a great idea ,I think I will give him a light and leave and the sound booth when no one is around,
:+1: … :+1: ……………. ![]()
Amen, sad indeed. And that statement, just as sadly; is far more reaching than flashlights…. ![]()
Reading between the lines and through the cracks and around the corners, as troubleshooters have to do, I would still like to make the case that your friend might be trying to find his ‘special place’ in your church’s ‘society’, by being ‘The Bringer Of Light’, and may not be just another equipment snob.
If that is the case, simply dropping off a nice flashlight might lead him to just drop it off in the trash. It wouldn’t matter to him if your flashlight really is “the best”; his place and standing in your group is what’s threatened, not his lumen count.
Addressing his social needs (assuming that’s the case) would both strengthen your relationship and reinforce his social standing in your group. In that case, gifting him one of yours “as a backup” or “for your other hand” or “to lend out to the unenlightened in times of need” would allow him to save face and transition away from his “monster” to yours. Sometimes “I’ve got your back” wins more friends than “I’ve got your flashlight.”
But that’s just what I think. You’re there so you know.
I do hope this works out to the best for both of you.
And warn any aircraft nearby that they may experience a burning sensation, flying over your church while you guys are outside playing with your flashlights!
Good Advice. Please think about it.
Well I took all blfers suggestions into consideration, and I seriously did not want any tension or negativity between us so ;I had an old but new ultrafire C8 which I immediately disassembled ,installed a new anti-reflective lens installed a new xplhi v2 emitter with artic silver a mountain electronics dd fet driver and new slightly deeper smo reflector, did a spring bypass on tail cap ,put in a box and said it was to be a back up light for him to do with as he pleased,he saw it played with it and said it was nice and gave it back to me ,I think he thought I was just showing off a new toy when I told him it was his the entire atmosphere changed and tension was gone .After service he gave me a big sincere thanks you and offered me his monster power star v2 3300 lumen light,which to him is a lot!I thanked him for his offer and said no thank you,he asked me why I gave him the light ?Well to be honest this is the truth is was given my best lights by a stranger who was on this forum only a couple of months ,and in those two months he ,out of the kindness of how heart sent me a Fenix K40,Shadow Terminator, a acebeam k40 modded by Vinh,an acebeam k60 xhp 70 and a meteor 243 with xpl hi’s modded by Vinh I white so taking a que from everyone in this forum is passed on on what so many other members have done for me like Johhny,Richard of MME vesture_of_blood and Tom E have done for me.And as well I think restored a strained relationship.
So thank all of you blfers for everything!
That is good !! Thanks for the update Lj……. :+1:
Nice gift, good result.
