We had a fairly warm and clear night on Saturday, so what better to do than a few beamshots! All were shot with a Canon 5DII at ISO 400/10sec/f.5.0 with color temperature for the white balance set at 5000k at a distance of 110 yards to the center of the first tree. I will adjust the overall exposure down some for the next set. But, this gives and idea of the spill and artifacts in the beam and reflector. I will add more to this page as I take them. Still to come, KD C8 with a dedomed XP-G2 2C, the Courui with dedomed XM-L2 0D and various configurations of the X6
So, on to the show…
This is how I hold the light and the camera. Sorry I forgot this pic in the OP.
KD C8 with 3 amp regulated XP-L HI 1A dropin.
Convoy C8 with 3 amp regulated XM-L2 1A dome on.
UniqueFire UF-2200 with a FET driven XM-L2 4C. I really love this light, it is old and less the elegant but wow!
SupFire L3 with a FET driven XM-L2 1A dedomed. This beast pulls 4.92 amps from a King Kong 26650 and does not overheat!
Courui D01 with a FET driven XM-L2 U3 1A dome on and 4.72 amps at the tailcap. It is going to get a dedomed XM-L2 0D once the parts get here!
SRK with JB-A modded driver and dedomed XP-G2’s
Last but not least a BLF X5 3B. This thing is just incredible!
Adding a few more today… I have cut the exposure down to 5 seconds, but still ISO 400 and f/5.0. Trying for more realistic shots. These look more lifelike.
KD C8 with FET driven de-domed XP-G2 2C
KD C8 with 3 amp regulated XP-L HI 1A dropin. This one was done above, reference shot here for new settings.
I will do that sooner or later, but most are fairly familiar and boring. I do find that setting the color temperature on 5000k give fairly eye realistic tint pics.
I really like that light, it has very good hand feel and while only having a 37mm diameter reflector, it is a very deep reflector so you end up with some throw. It really makes it a very universal mid range light. I have an Ultrafire F13??? tail switched light that is very similar. I am collecting parts to build it at the moment. It will also be an XM-L2 4C, that is my tint sweet spot for a general purpose light. I will use 3C’s and 2C’s from time to time. I have yet to play with anything above a 5, I would like to try a 7A at some point. I grew up with incans, I really hate cold blue’ish leds.
BTW, the UF-2200 does have AR glass I was able to find a 36.6mm on one of the sites and it works great since the front of the reflector is fairly wide and it has a good o-ring. It is a strange build in that it has a retainer ring that screws down against the reflector to tension it, it does not rely on pressure from the mcpcb to align it. The tailcap retaining ring must be tightened about every 3rd battery change or it will flicker under heavy load and this one does draw very hard, almost 5 amps at the tailcap.
This is the light that has convinced me that I must get a Trustfire A8. The A8 is closer to a tube light, so I do not expect quite the throw that this one has.
They are not hard. The worst part is getting focus right and you have to have a decent tripod since the photos are taken with a relatively long exposure. For something very realistic I would look for ISO 400, f.5 and around 3 to 4 seconds of shutter. Also set your white balance somewhere around 5000k, it seems to provide a very realistic led tint indicator.
The 5DII is not the latest either, just happens to be full frame. What model are you using? I had a 20D and it would have done just as well.
Yes, exposure value. These are a little hot to show rings and other beam artifacts. But they are nor rediculously hot either. I had to base line on one set of exposure settings for the series to be consistent.
It’s a Rebel XT aka EOS 350D 8mp about a 2005yr model. I have several lenses 75-300mm, 28-210mm & 18-55mm. I’ll have to get the manual and start experimenting with it. Bought it about 5yrs back from someone that upgraded.It’s a beater that is used while hunting from tree stands and some of the lenses are from an old AF 35mm SLR. Bought the wife a Canon 500D a few years back.
The 28-210 will be a good choice, the color reproduction on that lens is not great but it is a very utilitarian lens. Put it on M, set ISO 400 and about f6.3 with 6-8 seconds on the shutter and work from there. I started many years ago in digital with that body, not a bad body and it does see some IR!
