So I built my first 219b light this morning. OMG that tint is awesome! I see why so many people rave about them. But, I could not find a 3.5mm centering ring to fit a standard XM-L reflector. Do they exist? Could someone point me toward one, please?
I have used xp centering rings for nichia and they work with a bit of sanding (as you will need to when using with xp-l). I don’t think there are centering rings made specifically for nichia, they’re not that common as cree’s.
The standard XP-G to XM-L reflector centering rings will fit. I think linked about.
But they will block out some of the light and can cause an odd donut image on the hot spot. Not the regular donut, more of a shadow or something caused by the ring.
I don’t run centering rings on any of my Nichia lights, I find most stay pretty central anyhow and you get a better beam with a slightly off centre LED than you do with a perfectly centred one + the ring.
The p60’s from Int’l Outdoor with the Nichia219 in don’t use a centering ring either. They use one of the 3M style stickers to protect the wires from the base of the reflector.
I use an emery board to sand centering rings down when needed…
In my case, I was able to get good results from the FastTech centering ring without modification. The rings were older though, and looked similar to what Richard shows on his site, vs. what FastTech shows on theirs… That may be the difference as FastTech’s current model looks inferior.
