Dhbwa
(Dhbwa)
June 13, 2012, 3:35pm
1
Looks like I can’t avoid it…. Was going to try to stay with AA or CR123A batteries.
Is there a decent 2 battery charger for $15 delivered? What about decent 18650 batteries?
I just bought this and I assume the charger and possibly the batteries are junk??
http://www.ebay.com/itm/251069428700?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2649
scaru
(scaru)
June 13, 2012, 3:39pm
2
Well currently there is a group buy on the intellicharge. This charger has 4 slots and can charge any lion battery or any Nimh. It is 20 shipped with the 10 percent off coupon.
Vieplis
(Vieplis)
June 13, 2012, 3:47pm
3
The battery probably is. Check the charger’s max voltage; if it is 4.2V, the charger does the job.
I’d guess charger is junk too, with no proper termination.
You can get Xtar WP2 II for $15 if you’re lucky, and decent batteries would be pair of Xtar 2600mAh 18650’s for $13.5.
Dhbwa
(Dhbwa)
June 13, 2012, 3:50pm
5
Scaru- how do I get in on it?
scaru
(scaru)
June 13, 2012, 4:01pm
6
Go here.
Follow the directions. Then order.
bose301s
(bose301s)
June 13, 2012, 7:23pm
7
I would recommend the WP2 II as well, have had great luck with mine. Those are also good batteries, could also get these, http://www.ebay.com/itm/Keeppower-18650-3100mAh-Built-In-Panasonic-18650-Cell-2-pack?item=270965512744&cmd=ViewItem&\_trksid=p5197.m7&\_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D4%26po%3DLVI%26ps%3D63%26clkid%3D9112124259662670582#ht_654wt_952 off $21 and they will accept it.
Dhbwa
(Dhbwa)
June 13, 2012, 7:31pm
8
Scary- link to a DD flashlight?
For the light scaru posted cells with lower capacity would be better because of the steeper discharge curve.
scaru
(scaru)
June 13, 2012, 7:46pm
10
Dhbwa
(Dhbwa)
June 14, 2012, 3:14am
11
Boaz
(Boaz)
June 14, 2012, 9:44am
12
Those batteries are notoriously garbage ...and is that a version 1 or V2 ???
Ebay is a bad place unless you know exactly what you want and get it from a reliable seller.... lots of bad stuff being peddled on ebay
dino direct deal is 21$ which means they are getting 12$ or more for 2 red ultrafire 3000's ...i have a pair of ukltrafire reds you can have for .75 cents each ..they say they are 3000mah but they are really about 600..worst battery I've ever seen
Dhbwa
(Dhbwa)
June 14, 2012, 12:48pm
13
Thanks Boaz, I’ll buy a charger and batteries separately.i really prefer US sellers.
