I think I finally won against the glued bezels
https://imgur.com/a/ewEbd9v
You will need:
2 Small Rig super clamps
1 or more fingers from a heavy duty shop rubber glove
The super clamps are great BUT they slip. They slip with duct tape, gaffer’s tape, masking tape and no tape. So if you cut off the fingers of a heavy duty shop glove, they are almost the perfect fit around a FWAA/TS10 and they slip a lot less than any tape I have tried. A little turbo action helps heat the glue as well. It’s about 15$ for both clamps and they are good for other stuff too. I think I finally won against the glued bezels.
Some rubber strap wrenches might come in handy.
I switch between those clamps and some strap wrenches.
I have some locking pliers and rubber but those can sometimes damage the flashlight.
Those tend to work on bigger lights but the ones I have are too big for 14500 lights. The new FWAA assemblers use a whole tube of Loctite per light I swear. I have used combinations of vice grips and a bench vice but I end up either scratching the light or making some part oblong half the time. So far this method has been scratch free and haven’t been beaten yet.
I use a hot air heat gun. Heat the glued in place bezel, head whatever to soften the glue. Then unscrew it with a thick leather work gloved hand.
Mostly I use the hot air portion of my rework soldering station but I also have a general purpose heat gun I have used for larger heads.
Thanks Don! What temperature do you usually set your gun to for this?
350F with the soldering station heat wand. With the hot air “gun” it’s either hot or cold. My routine is heat and try to twist… repeat until it comes loose.
A friend who is a gunsmith told me that red locktite takes 325 F or more to soften.
