I want to build cheep thrower. Need advice...
I am decided to buy a new thrower to modify it.
I think to choose something like C8 or A60 (with a big reflector).
The idea is to put in the XR-E R2 LED emitter (I have chosen this because it seems that it has a good color tint and good heat transfer).
And this driver (because I need just one mode, and I think that the 1400mA for XR-E R2 is a very good current).
Please suggest me some cheap but good body (it can even be completed flashlight) with a big reflector - aluminum would be good. It would be good such whom can put in 20mm star.
And, whether it is worth to replace Q5 with R2? or R2 will be worth it - or be able to see a difference at all?
Currently idea to order this: C8 body + Aluminium reflector + R2 on 20mm star and 1400mA driver
or simply to order this: Ultrafire X1 + 1400mA driver
What do you think?
Cost?
I recommend XM-L Thrower. You will have more output , bigger spot.
If not, change driver to link below and add resister for more current.
For XR-E I don’t use 7135s because It needs more Vf to LED. 3.7-4.0V to LED @ 1.5A + 0.7V driver drop voltage, so It needs at least 4.5V up
http://dx.com/p/18v-5w-cree-circuit-board-for-flashlights-16-8mm-5-5mm-26110?rt=1&p=2&m=3&r=2&k=1&t=1&s=127685&u=26110
Cost up to around $20.
or XML really is well? I’ve seen several XML-flashlights and I did not like the light output - the light is too floody (and also eat batteries much faster and more heats). I think that a well-powered XR-E R2 can throw better, unless you dont have huge reflector…
Can you trust DX to send you an R2 binned XR-E? They are extremely hard to find anymore.
-Garry
I guess my question would be how far do you want it to throw rather than how big an area you want it to light?
I don’t yet have a really high output XM-L thrower, I do however have a Small Sun ZY-13 (XM-L T6) and a Crelant V9CS (XM-L U2). They are both lovely lights and are certainly aimed at throwing rather than flooding, but my 180 lumen XP-E MagLite will out throw both of them.
Or there is reason not to believe?
Yes - I am more interested in far throwers, not realy laser beam or pencil beam, but something more like like C8 with XR-E or Jacob C60…
Sounds like a good driver… I had not even noticed this. Or is it Buck and Boost regulated driver and gives out linear output? or output current is fixed (1.25A), or it is relative and depends of the Battery and LED? Would like find out more about this driver…
I just not sure - that I could add resister for more current… It may be difficult and there is certainly need for some hot air soldering iron…
but if 1.25A is real output, I think it would be enough for me (fot XR-E R2 or Q5)
