ICR 18350 suggestion
Hi guys, I already ordered a couple of Keeppower IMR 18350 750mAh as suggested by many (at the good price of 7.58 USD for the pair using the discount code)
Now I would like a couple of cells for maximum runtime at lower drain modes (tailcap current in the 200-800 mA range) so I should probably get a couple of good ICR cells around 900 mAh. Any suggestion of good deals available at the moment?
I have read that the protected ICR Keeppower 18350 doesn’t fit some flashlights because it’s too long. I’ve seen the complaint on the Nitecore EC11, BLF A6/Astrolux S1, and the Convoy S2+. That’s something to keep in mind as you look for ICR 18350s.
you are right, thanks. I’ll try with my IMR 18350 and a coin as a spacer to check how long I can go.
