I had alight that was I think shorting on the Led / Reflector. I was looking around and then I found something
Avery 05270 Reinforcement Labels
These are used originally to strengthen up the holes in paper to make it last longer in a binder
Be right back…
yeap it worked perfect. Fixed the short issue
https://www.google.com/search?q=avery+05720&hl=en&source=lnms&tbm=isch&sa=X&ei=nP8rUceRGoLIiwKF4YCIDw&ved=0CAoQ_AUoAQ&biw=1024&bih=677
i´ve used this solution too. Plastic spacers are very nice, but my father had a few of these in his desk…
A piece of paper cut to size with a hole punched using a Avery 3-hole punch works too. Generic 1 hole punch is too small usually, but a Avery 3-hole punch is sized almost perfectly.
Nice to know.
A couple pieces of tape on top of it's self and a hole punched works ..depends on the tape strength and thickness
