If I was to lose my mind.....
Now I don’t mod flashlights… But I want a couple really good throwers…. If I was to go out and buy the fenix TK70 & TK75 would this be foolish? Are they so similar that I would be wasting my money? Which is the better of the two? I am preparing to buy both…
Mwahahaha! Now there's no escaping us. :D
I would personally just stick with the TK70 though. The TK75 isn't as good of a thrower.
Just get the tk70 and another fare more different.
Now imagine I have no clue… Because I truly don’t…. But what makes the TK70 the better of the two?
More throw because of the deeper reflectors.
Not really… But I had to day it… The new TK75 is claiming 2800n lumens with on helluva big head… Scaru… Is there a really a difference in the reflective surface? If so what is the difference?
Size, it's all about size. :P The added brightness is because it is U2 rather than T6 but they rate it for less throw.
TK70=130.5kcd=720 meters
TK75=92kcd=606 meters
What do the CD numbers stand for… and how are they relative?
What is the difference between the X6 i just ordered and the TK70?
cd = candela = a measurement of intensity. higher candelas = higher concentration = more throw.
the tk70 will throw further than the tk75 because of 2 factors actually, it has a wider reflector and it has a deeper reflector. This means the tk70 head has more ability to bounce the light forward. any light which doesn’t touch the reflector forms the spill. More ability to bounce light forward = less spill = more intense hotspot = higher candelas.
The trustfire X6 isn’t really a great thrower mainly because it uses an SST-90. This is a bigger emitter than the XML. The smaller the emitter, the better the ability for the reflector to bounce it straight forward, because it’s coming from more of a point.
Your X6 will give you 45kcd, which throws pretty far, but nowhere near the TK75 or even TK70.
Lumens isn’t necessarily a big factor when you look at throwers.
the kcd is how far it throws. More kcd is more throw. The TK70 will out throw the X6 and put out more total light. The X6 is cheaper though. :P
TK70 has another feature is to flood a room by ceiling boucing.
It bouces as good as TN30, It throws as good as TN31.
WEll DENGOH, any light that can tailstand can ceiling bounce essentially.
Sorry not being clear about it, I means TK70 massive output can be useful to flood a room by ceiling bouce.
It is both a throw and flood machine, while TN30 is a mostly flood and TN31 is mostly throw.
Now I think Fenix try to do it again with TK75. Due to size, Fenix has to sacrifice throw a bit more.
