If you were to build a 1*26650+XHP50/70: which parts would YOU choose?
I’m thinking about building myself either a XHP50 or XHP70 1*26650 flashlight.
My goal is a compact light capable of 2500+ lumens, using some kind of 1*26650 host. I would like to drive the led fairly well, which could be a challenge both in regards of heat production, needed battery output and choice of driver.
Building such a light from components available at our “usual” sources, which parts would you guys use ?
Which host and reflector? Why?
Which driver? Why?
XHP50 or 70? Why?
It’d be interesting reading the thougts of some of you that’s experienced in building custom lights and modding. There are so many of you with lots and lots of experience (which I still lack).
Any thoughts ? :smiley:
Besides a few factory lights, is anyone making a boost driver capable of powering these emitters from a single cell?
I'm pretty sure the boost driver from DQG triple is said to be suitable.
http://www.cnqualitygoods.com/goods.php?id=2067
Wish I could get Ric to repond to my emails about getting one for the failed one in my triple though.....
Are the emitters in that light not in parallel?
I think it is in parallel indeed. Think I saw a thread about it’s driver somewhere here on blf.
Edit: found a thread about it: boost drivers for 6v leds?
And here’s the driver: http://www.cnqualitygoods.com/goods.php?id=2198
Hmm interesting I wasn’t aware of this driver. Thanks for the heads up.
On the host I’d pick the Shadow JM07 or the Convoy L2 or L5. I’d also stuff it with copper shot rich potting material around the head, under the reflector and in any void it has.
Reflector, orange peel to blend out the x that these quad dies produce.
Drive, well I don’t think it exist yet but people are working on it.
LED, XHP50 for the smaller single cell host its a trade off with throw and flood. With the smaller reflectors 2500 lumens from this die still should throw through sheer volume.
Seems I might have set out on a difficult task. Have looked around at the forum and have done some searching on google, but finding a driver solution seems a bit hopeless atm.
Is there really no such thing as a 3 volt input to 6volt output boost driver yet? :_(
I just bought the Shadow jm35(mtg2) from bangood.uk, its a small light powered by one 26650 with mtg2, please check this out it has a boost driver and it also works on xhp50, maybe you can mod the driver too for more amps.
Sorry when I commented no single cell driver around yet I was thinking of a 17-22mm 12 volt output not a larger 6 volt. There is already a single cell light out in MT-G2 and XHP-50 and its the Shadow jm35.
but I wouldn’t trust the qaulity of his lights products or customer service out the three expensive new triple xhp70 edc none worked and butchered and I ordered several parts and I never recived the tail switches and filed paypal disputes and won better off getting stuff fromBangood
On the flip side, I have had 5 orders of parts/hosts from CNQG go flawlessly (which I can’t say for banggood) although I have not bought a full light from him.
I am planning something of similar size, but with 3 x 14500 and a buck driver. I have a driver on order from International Outdoor, but would appreciate suggestions. It should work, but have short run time. I have not seen a three amp. six volt boost driver advertized.
be really neat to see if the voltage can be brought up
Wondering what the efficiency of a 6v boost driver would be like. Any known performance issues with boost drivers?
For example compared to linear drivers which i have a little more experience with?
Nothing is free and a boost driver looses some in the step up. I think the figures shown are around 80–95 efficiency. That loss is heat in the circuit 20 watts 80% efficiency and you have 4 watts of heat in your electronics to bleed out. 95% and it’s only 1 watt to bleed out. So those numbers and that sweet spot are going to be more important than easier led cooling I think.
Thanks for the approximate numbers.
Allowing myself to bump this thread in case any of the driver/electronics wizards missed the thread :wink:
Really feel like there should be a 1*26650 XHP light :cowboy_hat_face:
Anyone ever come up with a voltage upscale workaround for cases like this?
You and me both. I much prefer single cell lights or compact side by side configurations. If its too big for a pocket then it’s probable still at home.
+1 and we need more then one option.
Correct me if I am wrong but “good” 14500 cells are about 800 mAh so in series you have 3.6 x 3 but only 800 in capacity in parallel you have still have the boost issue but now 2400 mAh. I don’t see why one would change from 1x 26650 to 3x 14500 run in parallel. 2x 18650 would be much better if comparing both in series.
Now for the spark sx5 which can run 3x AAA, 3x AA, 1x 18650 or 1x 26650 now if that driver could be updated to run 6v emitters and 3x 10440 and 3x 14500 cells NOW THAT WOULD BE A COOL DRIVER!
Hint hint
