I'm ready to give up I'm so frustrated.
i can't figure out what's going on these days. I don't know if it's me, my DMM or what. I really haven't been happy with my current readings lately. 7A-8A readings with DD FET drivers and 30Q cells driving triples and quads. My builds are excellent with great care taken to eliminate all resistance possible. My DMM, not a fluke, but not cheap ($150 range) seems in good order with good batteries. I've never had problems before. But lately...
Last night I stacked four chips on a Qlite rev. I'm not very good at it, but everything checked out perfect for continuity, with no bridges. When I tested it,(the usual wires and alligator clips and magnets setup) I only get about 2.4A. That really frustrated me, so I tried again with a brand new unstacked Qlite and got about the same. Then I tried a New DD FET driver with about the same results. What is going on??? I grabbed a known light with a 7A buck driver and MTG and got 7A.
Nothing is making sense with my latest DD FET builds compared to what others are seeing. I'm getting so frustrated not knowing if I'm doing something terribly wrong or I'm getting tricked. I'm afraid to install a driver not knowing if my readings are false, or if the driver sucks.
did you try other leads?
Yes, and checked the batteries and even swapped the fuses for new ones.
Did you test the driver before the mod?
Get a cheapie clamp meter.
I ordered a clamp meter through freeme’s group buy. So far all I’ve got is a fake tracking code.
No I didn’t. It brand new, never used. After I tested it I hooked up another new one and got the same reading. Hooked up a FET driver, it was low too. I’m talking 2.6A on high. Not making any sense unless there was just so much resistance from all the wires and clips. Like I said, I haven’t been happy with the readings I’ve been getting with my builds lately. They seem so out of line with what other are getting, and these lights are built and wired meticulously.
What bugs me, is when I test old lights with buck 5 and 7A buck drivers, the readings are true.
This one is fulfilled by amazon so the shipping is fast and reliable. I had it shipped to a U.S. address so I had it in 3 days.
Just like you I found my DMM unreliable in measuring current. It always read way under what I was expecting.
I dont know. I never seem to get what others get either but as long as I compare what I mod before and after and get an expected improvement I’m happy. That is with the light meter and current meter.
According to your OP the meter isn’t the likely culprit if you are getting 7A on a known 7A buck driver.
Did you try swapping out the fuse in the multimeter? I have seen the end caps loosen and they can do some wonky things when that happens. Thats about the only other thing I can think of.
Bob
I scrapped all the test wires and tested the driver installed in a flashlight. I got 3.5A. With four extra chips it should be more unless I burned up three of them during the soldering. I then installed another new Qlite in the same light and got 2.8A. Should be 3.04A. Something’s wrong there. I checked, and the AMC chips are 380s.
I tested a couple other lights that had qlites installed and got 3.04A bang on. This is frustrating.
Seeing as how safe it is to assume you’re measuring the old and the new the same way, Wouldn’t that rule out the meter?
Maybe one of your components is out of spec (or the batch was, if you have more than one), or a trace (or a via) on your boards has been thinned without your knowledge (to something like 26AWG size)?
Are all the low readings coming from the same host with different drivers?
Do you rely on the driver pressed into the pill for your ground path there? Maybe you could try using a solder bridge at the edge of the driver, connecting to the body, just to be sure?
Yeah. I realize components can’t be trusted from driver to driver. I’ve always trusted my DMM, but before FET drivers and noctigons came around, it was pretty big stuff to attain 5A. Im still finding it hard to get readings much higher than 8A with my FET drivers and single cells. Maybe it doesn’t like that. I’ll know if I ever get my clamp meter.
I’m also wondering if my DMM gets more accurate high readings on the buck drivers because of the multiple cells used to drive them. I have no clue.
Edited:
If you have checked other Qlite drivers and gotten 3.04 and then you get 2.8 from this one, it is a 2,8A driver. Not as specified, probably 350mA chips that were labeled as 380mA.
Test a single chip and see if you get 350 or 380mA with just the single chip. Solder the wires directly to it and the led and test it.
These new leds you tested, were they all out of the same buy and are they all the same bin? Did you test an XP-G2 versus an XM-L2 and get the same readings from the bare leds? Or, did you test more than one of the same leds, like XP-G2? If the same leds all come out with low amperage, then you try a different led, like XP-G2 versus XM-L, and they come different, then it probably means all XP-G2 the leds tested have higher resistance? Could easily be a bad lot of leds and or a bad lot of chips. I have seen it happen a few times.
Just make an orderly test. Set up 3 of the same led and test each one direct and record the amp draw. Then set up 3 of another type of led and do the same and report the numbers. We can see something from that maybe.
Then whatever you get out of a driver, if it's close to the bare led, especially a FET driver, that means it's probably working ok? You can't push any more current than the led will take, no matter what. (That was a dumb statement). If the led needs 4 volts to get to 4 amps, because of resistance, then that is the limit of the led. (Well, isn't it?). The same led from a different run could get a different reading entirely.
Just my thoughts, not necessarily more than random thoughts and probably incorrect random thoughts, but it's not the first time I put my foot in it.
I tested the drivers on several LEDs. On old XPG, an old XML2, which very well may be a U3 which I think can be a be bit flaky. I also tested it on an XPE triple. I was getting the more accurate readings when I tested them installed with a known XM-L2 2C.
The chipped driver that only gave me 3.5A could have been only2.8A from the start, and I am willing to admit that I may have done something bad to a couple chips trying to stack. Both those IOS drivers were in a bag that I had marked “Qlite Rev A ?”. I think I bought ten of them the first day Hank introduced them. If I remember correctly, they were all a bit flaky and I marked the bag with a question mark.
I just installed another Qlite from a different bag. Just a quicky test with the tiny wires that melt, and not soldered into the pill. 2.93A. That seems about right.
Maybe tomorrow I’ll use that one and try my hand at stacking again. I’ll try to be careful with the heat. If that fails, that’ll be my final attempt at stacking. I was so confident that last one I did would be good.
I’m starting to become a crusty old determined crank. I’ll get those damn chips stacked no matter how much my cat howls and scratches my legs just trying to get some attention.
Can you share a picture of your measurement setup? The fact that you said buck drivers deliver expected current makes me feel like its a contact resistance issue.
Have you tried measuring the Vf of the emitter? If it’s close to Vb then the emitter is the problem. I’ve heard similar complaints lately.
