Finally! I got Imalent MS08 in mid December, couple of days after real winter came. so i`ve waited until mid of march when snow melt, then began weeks of rain and fog - no chances to make outdoor pics. Now, after almost 5 months, this is not really new model, like it was when i received it. But it is still very bright and unusual flashlight. Flashlight, to which incredible light, i bet, you would like to take a look at.
Let`s go.
Super-bright flashlight Imalent MS08. Wall of light in can size
If there is any brand that puts “wow!” at the forefront, then this is Imalent. The manufacturer is obsessed with squeezing as many lumens as possible out of any of its models. And since they combine an increase in brightness with making flashlights more and more compact, then lightning-fast heating should also be taking into account.
As a result, Imalent decided that an external case with a built-in fan would just help to cope with this heating caused by the colossal brightness. The first model with this wonderful innovation is Imalent MS08, review of which I offer you.
you can buy Imalent MS08 at:
➤ AMAZON
and don`t forget about Nkon.nl – i`ve bought batteries here since 2015. Recommend.
Specification:
- LED: 8*CREE XHP70.2
Maximum brightness 34,000lu
Maximum range 738m (136,000 cd)
Power supply: 3*4000mAh 21700 Li-Ion battery
Product size: 74 (head diameter) * 51 (body diameter) * 125.5 (length) mm
Net weight: 651g \ 783g (without batteries \ with batteries and plastic case)
High-efficiency circuitry maintains 10,000 lumens at all times (ah, those sweet words)
The built-in thermal control module and fan-powered heat shield automatically adjust the output brightness according to the working condition and outside temperature, ensuring comfortable use.
Tempered ultra-clear mineral glass with anti-reflective coating
Aerospace-grade aluminum alloy body, Type III hard-anodized wear-resistant surface treatment
IPX-8 waterproof
1m impact resistance
PACKAGE AND DESIGN
Great premium packaging. Large black cardboard box with dust jacket, everything is very presentable
The kit includes the flashlight itself, 3 * 4000mah 21700 batteries, a holster, pair of o-rings, a manual, 2 (!) Charging cables. There is no lanyard, which is uncool as the external case is plastic and it is necessary to reduce a risk of dropping flashlight out of hands of users.
The holster is pretty decent.
As I said above, the flashlight is not small, a little larger than the usual can-size format, largely due to the plastic case. But it is not really large as well.
Left to right: Wurkkos TS21 \ Imalent MS03 \ Imalent RC03 \ Imalent MS08 \ Convoy 4x18a
And so this is a slightly enlarged familiar can-size format. A sort of barrel of light. A “naked” flashlight size is completely usual.
But with a plastic case on, flashight gets unbelievably cool and futuristic look. I am sure that such a ribbed black case with a bunch of slots will simply hypnotize a lot of the buyers. It really reminds me of some stuff from “Prometheus” movie.
The flashlight looks exceptionally impressive. With such an abundance of slots, it will not be difficult for you to attach a lanyard there, which, I think, is simply mandatory for such a size and weight of a flashlight. But, of course, if you think that plastic can withstand a fall on asphalt or tiles, use it as is, with no holster.
However, the flashlight fits in the hand without inconvenience. It has a good tenacious knurling, but the plastic body gives a much more secure grip. However, let me remind you that the flashlight is not lightweigt, so the lanyard is still needed here.
The tail is flat, but the flashlight has a firm tailstand. If the light goes off, you can point MS08 to celing to illuminate room with reflected light.
There is a contact for charging the battery of the built-in fans and a button to turn them on. The button is very sensitive. If you put it on something soft, like on a mouse pad, the button will turn on. As well as the button will surely turn on if you carry a flashlight in your backpack. There is no fan lock. So there’s a chance you’ll just run out of fans by the time you need to get your flashlight out and turn it on. That is a drawback
The flashlight has two fans, they are located at the beginning of the head.
You need to unscrew the head to get to the batteries,
There are 3 thick springs on the tail side, and a contact ring at the head
If you dont use plastic case, there is simply no way to find button. I dont know why Imalent keep on making button that flat and damn inconvenient! Nevertheless, if you put plastic case on, situation gets way better, there is no problem to locate button.
Here pair tangible recesses appear: one for the button and one for the charging connector. One lies under the index finger, the other under the thumb. Since the button is flat, you won’t even understand where which is, and therefore I usually just press it with both fingers at once - the light turns on anyway.
Charge connector is Imalent starndart magnetic one. It is really good to get 2 charge cable in the kit to simultaneously charge both batteries and fans. If any wire is lost or broken, you will have a second one.
5v2a is not that fast for large overall capacity of 3 * 21700 batteries. Would be cool if Imalent add PD support.
There is a bolt that secures the plastic case. It is small and easy to lose. I think it would be good to add a spare one to the kit.
An array of 8 CREE XHP70.2 LEDs at the bottom of small, smooth reflectors is responsible for the light.
UI
Good UI. I find it undoubtly convenient. Nothing to complain at all
1 click - OFF \ ON
2 clicks - TURBO
3 clicks from OFF - LOW
4 clicks (times) lock
How Imalent MS08 works
Well, as usually, specification is different from what you get in reality.
Brightness I have no tools to measure it. But I will refer to measurements of one 1lumen, who got next: 1630 MID I \ 3850 MID II \ 8800 HIGH \ 25,000 TURBO instead of 2000 \ 5000 \ 10,000 \ 34,000 lumens.
The difference of all the modes up to Turbo is Ok for me, but real brightness in Turbo way less then promised.
Runtime
The specification promises 90 seconds of Turbo. But it is not clear whether Turbo will last 90 seconds and then stepdown to HIGH, or brightness goes lower from 1st second during this period.
Of course, the 2nd is close to reality - the brightness drops immediately. But, again, there is no 90 seconds here at all. U get exactly half of promised time. And that’s from a cold start.
If you turn on a flashlight that has already warmed up (real use situation), you get 15 seconds of a instantly falling TURBO.
It is, of course, just an eon and a kalpa against the background of those scanty 6-7 seconds that some other expensive (you know them) models offer. Even 15 seconds of such brightness that Imalent MS08 gives you are enough to highlight everything both far and wide. So numbers themselves are way not as impressive as light of MS08.
Of course, the built-in fans do not have the slightest effect on the runtime of TURBO. It believe you should use Imalent MS08 at polar night somewhere in Arctica or Siberia, where air will be cold enough to dissipate heat of such insane brightness.
Imalent promises “The high-efficiency circuit maintains 10,000 lumens at all times.” Even this brightness level is extremely, extremely high for a flashlight with such moderate size.
In past situation, all these promises were outright nonsense, let’s call a spade a spade. Even now, simple mathematics says that if the specifications promise 10,000 lumens for 55 minutes, and half the brightness but 85 not 1100 (1/4 less), then something is unclean here.
So I was pleasantly surprised to see that the Imalent MS08 is relatively close to keeping this High mode brightness, if not with promised full stabilization, but with some reasonable and useful decrease, not collapsing down.
After 3 minutes of HIGH, there is a decrease to a level of about 6600-6800 lumens. By the way, it is the level that the TURBO falls to, not to HIGH how specs promise. But then MS08 still keeps a good brightness for 20 minutes. I repeat again - though there is no hour, neither 10000 lumens, brightness and runtime are impressive.
The mentioned MID II level is also not fully stabilized, but the stepdown is quite smooth and imperceptible to the eye.
The flashlight keeps this brightness even without forced cooling. However, even at this level (not to mention HIGH\TURBO) you still need a plastic case, otherwise you won’t be able to hold a hot case. So, this plastic case really helps when you use Imalent MS08 at higher levels.
MID1 mode also have runtime different from promised, this time difference is on the side of the user, who gets much more than 2h18min. The brightness will similarly not be stabilized, but it will take almost 5 hours to reach the threshold of 1000lum. and it’s very long. Taking into account the fact that MID 1 is quite really a lot, this mode gives you excellent light for almost the whole night.
As for the light, you get a good, comfortable near-mid light. The stock of colossal, breathtaking brightness will allow you, if necessary, to break through a couple of hundred meters, illuminating a huge area in width as well.
Conventionally, you can light up an entire football field in one go. It is possible to look further, but brightness will not be that good after like 200m. But, again. You can illuminate everything within this radius.
In general, aforementioned MID 1 is really good walk around mode. It will allow you to illuminate the road very well in front of you very well, both far and wide. Let me remind you that the flashlight will work at this brightness for a long time.
MID II with will allow inspect the surrounding bushes and hills. An hour and a half on this mode is quite sufficient for an evening walk. Also really good combination of brightness and runtime.
of course, video Imalent MS08 video review contains way more example how this flashlight performs alive
OVERALL IMPRESSION
The main concept of Imalent is “more brightness in less size”. The consequence of this approach is the inevitable overheating, which may reduce all superbright turbo to the usual unpractical flash.
Since the manufacturer is unable to give up the race for lumens, Imalent decided to use a fan to combat overheating. All such flashlights, that I have seen, had a fan built into the handle. Immediately, Imalent came up with something fundamentally new. The plastic cover with two fans is actually quite good, with the effect visible on the graph, it cools the flashlight and now Imalent MS08 sustains the higher brightness more efficiently and simply lets you hold the flashlight which is already damn hot.
So in this regard, Imalent MS08 turned out quite well. It doesn’t have a decorative turbo. Even 15 seconds from hot start is actually a lot. And the way more stable High mode is even more impressive for its long runtime. Though, have to remind you - there is no promised brightness stabilization.
This is the rare case when Imalent promises great brightness and this brightness can actually be useful.
The question is, will this use be convenient? The flashlight has a fairly large body, which will fit not every hand. And if you use MS08 without a lanyard, then sooner or later the flashlight will drop and you have to new plastic case (Imalent also sells them)
That may not be problem if it happens in the forest. But what happens if the flashlight falls on the asphalt in the city? The case with the fan on the flashlight is plastic, so, if you don`t attach lanyard, I consider the chance that case will fall and crack to be really high.
Imalent MS08 is a flashlight that you can use at higher modes. But you have to be careful, holding it. You have to use a lanyard, you have to remove the flashlight from the edge of table and shelf. Actually, the same what you would do with any other can-sized (or larger) flashlight.
In general, I think that the flashlight turned out better than many Imalent models that i tested. But plastic case with fans is the main functional advantage of the flashlight, and at the same time it is it`s weak point. It helps MS08 to keep the higher brightness and not let you simply burn hands.
Advantages:
Flaws:
- plastic case may break if dropped, to avoid this, you need a lanyard which is not included in the kit
- hard to locate button at head when use MS08 without a case.
- 2A is too low for such high overall batteries capacity , there is proprietary connector
- the fan button will be pressed when carrying and the fan battery is likely to be discharged by the time of use
- real difference between the declared and real runtime (both less and more) and brightness
+21700 batteries with huge run time
- built-in charger
- colossal brightness
- good set of modes and mode spacing
- convenient UI
- built-in fans
- the ability to sustain really high brightness
