If you are talking about comparing candela readings at a distance then this is fundamentally flawed. It will not work.
Perhaps it would be better to measure a single emitter in the TA Tube. Find a way to block the other 8 emitters. Perhaps use tin foil with shiny side facing into the tube. If you can effectively block all light from the other 8 emitters (maybe through the use of multiple layers) then you can accurately measure the one emitter. Then multiply the results by 9.
This requires we assume the other 8 are just as bright as the one we measured.
I do suspect the TA Tube losses some accuracy on these mega powered lights.
