Just bought some top of the line Panasonic 18650’s. 3.7V 3400mAh protected
button top batts.
Am I supposed to immediately charge these? (because that they might be run down?)
button top batts.
Check the voltage. If they are around 3.7v, where they should be for storage, leave them in the fridge until you are ready to charge and use them.
If you intend to use them now, then charge them and use them.
Newly manufactured li-ions are not fully charged. They are only charged up to a “storage” level as telephoneman mentions. This is because li-ions age slower when only partly charged. If you ever received “new” batteries that are fully charged then they aren’t new.
Thanks for both replies. Makes sense.
(Had to drive into town to get that tiny 23a battery for my volt meter)
Ncr18650B batteries by any chance? I just got some myself.
As a practical reference, 4.2v is full, 3.7v is half full (best storage voltage), 3.0v is about the lower limit of an empty cell. Usually a flashlight with over-discharge protection will cut off at 3v for safety.
Never heard of leaving them in the fridge before? Is that only if they are new and never been charged?
Li-ions also age slower when kept cold. So ideal long term storage is cold and at storage voltage. But when using the batteries, cold will temporary reduce their output capacity / power. In the winter, warming a li-ion next to your body will let you get more out of them.
I keep a few of mine in the fridge but near fully charged in case I need them.
Cool and dry is most likely enough. Most chemical processes are slower when it gets colder. Not sure how much you gain from storing li-ion in a fridge. I have my spare cells in a water and gas proof storage box in a cool cellar.
But as already said, try to avoid long term storage of li-ion cells fully charged. That means they age faster. So they will loose capacity a little faster. But on the other hand, it is nice to have at least some spare cells fully charged as well in case of a sudden desire to light up the world.
Ni-mh cells should be stored fully charged, on the other hand. So if you buy new ni-mh AA cells, make sure they are fully charged at once...
That reminds me, I really ought to make better use of those perpetually empty fruit / vegetable / diary drawers in my fridge.
KuoH
Technically keeping them cool will increase their lifespan as most li-ions will die from age before cycles, the lower temperature slows down ageing while higher temps speeds it up. Cool though not too cold, while I don’t believe freezing causes any damage, charging them when at freezing temps can cause cell failure, more of a weather concern though.
How to Prolong Lithium-based Batteries - BatteryUniversity
Temperature |
40% charge |
100% charge |
Estimated recoverable capacity when storing Li-ion for one year at various temperatures
Elevated temperature hastens permanent capacity loss. Not all Li-ion systems behave the same. |
0°C
25°C
40°C
60°C |
98%
96%
85%
75% |
94%
80%
65%
60% |
Get some fruit man! Nature’s candy.
i charge all my cells and keep them in my basement (my workshop) where the temp is 15 to 18 °C
i do not want to “store“ the cells
i want to use them!
i grab one, measure the voltage and use it (or put it in the charger)
half or even 3/4 full cells make no sense… ![]()
Cool !!! (pun intended) Just got a fresh shipment of vtc5’s and 25R’s in, they are for future builds, just don’t need them now. Thanks for the tips everyone!!!
Wholesale Li-ion Batteries | Liion Wholesale – Tagged "Sony" – Liion Wholesale Batteries Wholesale Li-ion Batteries | Liion Wholesale – Tagged "Samsung" – Liion Wholesale Batteries
ItsOnlyMe: I don’t know what the B after your 18650 means - mine don’t have that B. I’m still learning.
Chenko: 4.2v full 3.7v half full Great! Thanks! I wouldn’t have thought 3.7v was only half full, I would’ve thought 85-90% full.
What does 25R mean??
Link to the batteries you bought?
25r is shorthand for Samsung INR18650-25R 2500mAh High current batteries.
That’s just part of the model number. All Panasonic 18650s are designated ‘NCR18650’. But the last letter (or two letters) designate the specific battery. For instance, A=3100mAH, B=3400mAH, G=3600mAH, BD=3200mAH high discharge, GA=3500mAH high discharge, etc. Of course, if your cells are protected, then they are rewrapped, and the model number of the cell probably isn’t apparent.
Wow, there’s so much to mere batteries.
Thanks guys.
Here they were: 4 Panasonic NCR18650B 18650 3400mAh 3.7v Protected Button Top Batteries
Embarrassed to say how much I paid for these - probably overpaid. $11 each, shipped.
Yep, upon looking at them with a mag. glass, they said NCR and had the B after the 18650; it just didn’t have it in the ad, no wait, it DID. I just didn’t know what that meant. Now to finish charging these babies up and put them in my K60!
But they start to get fuzzy and smell bad after awhile. Batteries won’t do that, at least not for a few years. :bigsmile:
KuoH
