Improving a zoomie
Hi guys,
I’m pretty new to flashlights, but was fascinated by them since i was litte.
I also like to tinker, since i can think. So the most obvious thing to do is buying a budget light and improve it as much as i can.
The light i chose is the new-108 3-mode zoomie. I like the ability to use 18650 and 3xAAA as well as zooming and only three modes.
I don’t have it yet, but will order it in the next days.
Fist thing: There are reports about a too loose zooming mechanism and some rattling. It’s supposed to be water resistant, but in this pic i can’t see any o-rings. If I’m right there should be two of them on the upper part of the pill.
Does anybody know which diameter these should be?
Second: I want to polish the inner part of the zoominghead, to make it shiny and reflective. This should give a lot more spill in zoommode, by just using the light that otherways would be lost.
Has anybody done this before?
Last: I will try to reduce the overall resitance of the system to improve current and efficiency.
Any more suggestions?
flo
It's good to have you here, plasmatree!
Welcome plasmatree,while I don't own this flashlight I would discourage you from polishing the inside of the light.This will create reflections and cause rings in the beam,I do the opposite and use flat black model paint to reduce the rings.The ring is black on the emitter anyway,so best to leave it alone.What resistance mod are you going to try?
1. You may have to add some, I have had to on some budget lights.
2. From what I’ve read on aspherics, you probably want the inside black under the lens.
3. Use good batteries from a good seller (such as kumabear on this forum).
