clemence
(clemence)
25
Not a problem. Ideally, they should be longer to the sides but any increase in die size will make it floodier anyways. You can also test by piggy back any new MCPCB on top the OEM MCPCB. Try to reorient it as required for best position and focus before final modification. Use low power input just enough to check the beam profile. After testing you should get more hold of what to do next
[Clemence]
