Indoor LED Par Light Single White/Warm White-F180D
Structure: New die cast model, made by high quality ADC12 aluminum, more stronger; Patent new lamp body is design to support heat sink, with better ventilation, no fans cooling, no noise! Temperature rises 25 degree in the full load; Could customize white/ Black housing.
Optic Design: Standard white light output, standard white, nature white, warm white, blue, etc, different colors to customize; Beam angle (10% intensity) 15 degree, 45 degree, Optional.
Electrical: AC 90~240V 47-63 Hz Input, 95 Watt max consumed, power factor 90%;
More than 35000 Hours Longevity for SMPS.
Smooth dimming, can replace 250 watt traditional Halogen, metal halide Par light.No need to change original primary dimmer rack circuit, no need to add extra DMX system,suits for applications as technology reform of stage, studio room, save wire and labour cost.
This product comes from:
Specification
Voltage input: AC 90-240V 47-63Hz
Max power consumption: 95W
PF: 0.9
Light source:18pcs*5W White color, 2800-8000K optional, warm white 200K as 1 BIN, standard white 500K as 1 BIN, Standard white LED 5340 Lumens Output;
Dimming: Primary side dimming Smooth dimming curve
LED Life Span: 50 000 – 100 000 hours
Beam Angle: 15°、25°、45°、60° optional
PWM Frequency: >7.8KHz, flicker free
Cooling method:Natural cooling
Net Weight: 3.5Kg
IP Rate: IP 20
This is something I would like to light up a pool party at night.
yep,This product can produce light moderate, but very shining
