Wanna know where I found them?
Inside these:
http://lygte-info.dk/review/batteries2012/Keeppower%2018500%201500mAh%20(Black)%20UK.html
Was hoping for Sanyo..
Inside these:
Seems somewhat deceptive as I think they sell them as being Sanyo core, I would complain to whoever sold them to you or try and contact Keeppower.
Looks like they are made by Great Power Battery Co Ltd
Here’s what looks like the datasheet
I contacted my retailer already. It seems that Keeppower is claiming Sanyo but using different cells. If you compare HKJs test with these graphs:
you will notice that he got 80mAh more out of the same cell, but he discharged to 2.8V. So I assume the cell he had was the same as the one tested one dampfakkus. And they also tested the bare Sanyo cell which had a "lot" more capacity, more difference than we usually see between protected and unprotected cells.
I dont like that.
@Spasmod: Thanks a lot! How did you find that. :D
Remember that my test was nearly a year ago, they have probably decided to use another cell since then.
On my battery it says: "Cell & IC made in Japan".
Cell & IC Made in Japan
Assembled in China
Are you sure that yours use the Sanyo cell or do you trust the specs?
I trust the specifications, I usual never check inside.
With a Chinese battery inside and a text saying "Japan" outside, I would say you need to complain.
